查看: 3974|回复: 4
[招聘] 成都大型集成电路外资招聘IC Layout Engineer(工作地点:成都)
发表于 2011-5-10 23:46:30 | 显示全部楼层 |阅读模式
职位:IC Layout Engineer(无英文要求)
有意+QQ:1014565282。。。。。。。。。。加Q备:注(IC)
岗位职责:
1. Main responsibility is analog / mixed signal IC layout.主要负责模拟和混合信号IC版图设计。
2. You will be responsible for all levels of analog mask layout from floor planning, ESD pad placement, block level layout up to top level integration and tape out.主要负责所有模拟电路版图的整体布局、静电保护设计和模块到顶层的集成设计和流片。
3. You will communicate and get directions from the analog design engineers to ensure high quality. 主要负责与模拟IC设计工程师沟通并确定方向以确保产品的高质量。
岗位要求:
学历要求:全日制统招本科或以上
性别要求:
语言要求:普通话
年龄要求:25-35
总工作年限:2年以上
任职资格的具体描述:
1. 2–5 years layout experience.2到五年版图设计工作经验。
2. Understand the basic fundamental of electrical engineering.具备基本的电子工程知识。
3. Understanding basic characteristics of transistor, resistor, capacitor and diode.具备基本的晶体管、电阻器、电容器和二极管知识。
4. Understanding of layout impact on device matching, noise coupling from signal, supply and substrate.知晓版图设计对器件匹配,信号干扰,信号线及衬底的影响。
5. Understanding the importance of signal flow, power/ground structure and block placement in layout floor planning.知晓信号走向,电源及地线结构和模块顶层布局的重要性。
6. Understanding the importance of communication with analog designers.知晓该工作与模拟电路设计师沟通的重要性。
7. Must be familiar with DRC/LVS verification tools.需熟悉DRC/LVS等验证工具。
8. Must be familiar with Unix OS.需熟练操作Unix OS系统。
9. BS degree in electronics or microelectronics engineering.电子工程学或微电子学等专业,统招本科学历
发表于 2011-5-11 14:15:08 | 显示全部楼层
富记,,发哥,,奥特 还是没拍死??
 楼主| 发表于 2011-5-11 14:15:13 | 显示全部楼层
顶~~~~~~~~~~~~~~~~~~~~~~~~~~~
发表于 2011-5-11 18:19:35 | 显示全部楼层
Shortputts and long putts
areplayed with the same golf club even though the stroke pattern and purpose arequite different. Short newgolf clubsputts
demand club face control while thelong putts demand pace control. The short putting stroke should be as short aspossible to lower the risk of changing your club face position after
mx700 fairway woodaligning the club face at the target. The long putt stroke can be long andflowing because controlling the pace of the ball speed is your goal.
 楼主| 发表于 2011-5-11 22:26:20 | 显示全部楼层
....................................学历降职大专
GMT+8, 2025-12-20 04:13 , Processed in 0.024288 second(s), 8 queries , Gzip On, Redis On.
