关于.13的库OP仿真是碰到的:error : reference 0:p12_rf not found, or instance width or length does not fit into the wmax/wmin or lmax/lmin range. it was referenced in element 0:m1 the channel width=2.500E-06 and length 1.300E-07
error : reference 0:n12_rf not found, or instance width or length does not fit into the wmax/wmin or lmax/lmin range. it was referenced in element 0:m1 the channel width=2.500E-06 and length 1.300E-07
但是根据那个库文件中提到的最大最小尺寸,
确实没有错丫,愁死我了。麻烦高人指点下了,谢谢。
下面是我写的代码部分:
调用mos管的名字是根据那个库来写的,咋就识别不到呢? |
