查看: 11162|回复: 24
[求助] 有没有用Questa10.0a跑UVM 1.0成功的?
发表于 2011-4-16 21:54:07 | 显示全部楼层 |阅读模式
我按照网上的做法,老是不成功,抑郁了。麻烦告诉指点一下哈!
set UVM_HOME D:/study/uvm/questasim-win32-10.0a/verilog_src/uvm-1.0/src
vlog +incdir+$UVM_HOME/src hello_world.sv
# QuestaSim vlog 10.0a Compiler 2011.02 Feb 20 2011
# -- Compiling module hello_world
# -- Importing package uvm_pkg
# ** Error: packet.sv(29): (vlog-2163) Macro `uvm_object_utils_begin is undefined.
# ** Error: packet.sv(29): near "(": syntax error, unexpected '(', expecting function or task
# ** Error: packet.sv(30): (vlog-2163) Macro `uvm_field_int is undefined.
# ** Error: packet.sv(31): (vlog-2163) Macro `uvm_object_utils_end is undefined.
# ** Error: producer.sv(24): Undefined variable: T.
# ** Error: producer.sv(32): near "protected": syntax error, unexpected protected
# ** Error: producer.sv(36): (vlog-2163) Macro `uvm_component_utils_begin is undefined.
# ** Error: producer.sv(37): (vlog-2163) Macro `uvm_field_object is undefined.
# ** Error: producer.sv(38): (vlog-2163) Macro `uvm_field_int is undefined.
# ** Error: producer.sv(39): (vlog-2163) Macro `uvm_field_int is undefined.
# ** Error: producer.sv(40): (vlog-2163) Macro `uvm_component_utils_end is undefined.
# ** Error: producer.sv(46): (vlog-2163) Macro `uvm_info is undefined.
# ** Error: producer.sv(46): near "(": syntax error, unexpected '('
# ** Error: producer.sv(52): near "(": syntax error, unexpected '(', expecting IDENTIFIER or TYPE_IDENTIFIER
# ** Error: producer.sv(53): near "(": syntax error, unexpected '(', expecting IDENTIFIER or TYPE_IDENTIFIER
# ** Error: producer.sv(55): near "(": syntax error, unexpected '(', expecting IDENTIFIER or TYPE_IDENTIFIER
# ** Error: producer.sv(58): near ".": syntax error, unexpected '.', expecting IDENTIFIER or TYPE_IDENTIFIER or '#' or '('
# ** Error: producer.sv(62): (vlog-2163) Macro `uvm_info is undefined.
# ** Error: producer.sv(67): near "(": syntax error, unexpected '(', expecting IDENTIFIER or TYPE_IDENTIFIER
# ** Error: producer.sv(73): (vlog-2163) Macro `uvm_info is undefined.
# ** Error: consumer.sv(24): near "#": syntax error, unexpected '#', expecting ')' or ','
# ** Error: consumer.sv(25): 'out' already declared in this scope (packet).
# ** Error: consumer.sv(27): Multiple constructors declared for class packet - only one allowed.
# ** Error: consumer.sv(27): 'name' already declared in this scope (new).
# ** Error: consumer.sv(27): Verilog Compiler exiting
# D:/study/uvm/questasim-win32-10.0a/win32/vlog failed.
发表于 2011-4-17 17:35:08 | 显示全部楼层
找不到宏呢,兄弟Questa10.0a哪下的啊?
发表于 2011-4-18 13:47:16 | 显示全部楼层
我编译的时候,除了你上面的指令,我在编译hello_world.sv之前,把uvm_pkg给编译了一遍,就可以了。
 楼主| 发表于 2011-4-19 16:36:40 | 显示全部楼层
回复 3# gaurson
谢谢哈!我下去试试
 楼主| 发表于 2011-4-19 16:41:07 | 显示全部楼层
回复 2# whxqq
就在官网上面,注册就可以了。
eetop里面有下载的教程,不过链接我忘记了。。。
你可以找找看
 楼主| 发表于 2011-4-20 11:57:01 | 显示全部楼层
回复 1# cnzhang
搞定了,sign。。。
vlog -timescale "1ns/1ns" -mfcu -suppress 2181 +acc=rmb -writetoplevels questa.tops +incdir+$UVM_HOME $UVM_HOME/uvm.sv +incdir+. hello_world.sv
不过具体没有命令是什么意思还是要研究研究。
发表于 2011-4-30 08:28:52 | 显示全部楼层
uvm的例子里面有questa脚本,这个在modelsim6.5c中也是可以运行的,可能questa支持uvm更好些,不知道大侠的questa10.0a是在哪里下载的
发表于 2011-4-30 19:52:18 | 显示全部楼层
先下下来试试啦
发表于 2011-5-24 20:39:21 | 显示全部楼层
一会试一试
发表于 2011-5-29 23:07:22 | 显示全部楼层
顶一下
GMT+8, 2025-9-13 16:59 , Processed in 0.022448 second(s), 5 queries , Gzip On, Redis On.
