楼主: yawyw
[资料] HyperLynx Lab HDMI
发表于 2011-7-21 11:07:36 | 显示全部楼层
Thanks!
发表于 2011-9-19 16:15:32 | 显示全部楼层
Lab-HDMI.pdf (1.08 MB)=
Lab  — HDMI SI Analysis
HDMI Design Kit
The HDMI Design Kit includes a simple HDMI interface, consisting of a transmitter that
drives through board traces to a compliance point test load. The driver model used here is
the HDMI-compatible TMDS I/O pin of the TMDS341, a 3-to-1 DVI/HDMI Switch, by
Texas Instruments. The data rate for this channel is upto 1.65 Gbps
S8p model 1m HDMI 887689800.pdf (61.86 KB)=
TITLE 1m HDMI cable assembly
发表于 2011-9-20 01:28:24 | 显示全部楼层
Thanks
发表于 2011-9-27 11:00:21 | 显示全部楼层
正是急需的,谢谢楼主了!
发表于 2014-3-21 23:35:34 | 显示全部楼层
回复 1# yawyw
   goodlad
发表于 2015-8-3 00:14:43 | 显示全部楼层
谢谢楼主分箱
发表于 2015-8-18 20:10:05 | 显示全部楼层
发射点发射得分手段
发表于 2015-9-7 16:10:17 | 显示全部楼层
Thank you very much!!!
发表于 2015-9-8 07:11:18 | 显示全部楼层
Thanks
发表于 2017-3-6 13:45:35 | 显示全部楼层
确实不错
GMT+8, 2025-12-25 14:46 , Processed in 0.017769 second(s), 3 queries , Gzip On, Redis On.
