查看: 4017|回复: 2
[求助] encounter中添加RC Extraction中出现下问题,不知如何解决,请高手指教!!!!
发表于 2011-3-21 15:28:00 | 显示全部楼层 |阅读模式
Reading Three Cap Table files: -typical /usr/smic_0.18um_lib/smic_0.18um_logic_lib/Place_Route/Cap_Table/sc-x/smic_logic018_6lm_typ.CapTbl -best /usr/smic_0.18um_lib/smic_0.18um_logic_lib/Place_Route/Cap_Table/sc-x/smic_logic018_6lm_min.CapTbl -worst /usr/smic_0.18um_lib/smic_0.18um_logic_lib/Place_Route/Cap_Table/sc-x/smic_logic018_6lm_max.CapTbl ...
Cap Table was created using First Encounter 08.10-s207_1.
Process name: smic_logic018_6lm_typ.
**DIAG[dbReadCapTbl.c:1849:dbiParseCapValLine]: Assert "layer_id != -1"
**ERROR: (SOCEXT-2715): Syntax Error in line 3
Usage: readCapTable {-typical <fileName1> -best <fileName2>
                    -worst <fileName3> | <fileName>}
**ERROR: (SOCSYC-194):  Incorrect usage for command 'readCapTable'.
**ERROR:
**ERROR: (SOCSYT-6729):
encounter 1>
发表于 2011-3-21 16:17:32 | 显示全部楼层
应该就是capbable有啥语法错误, 读不进去,
GMT+8, 2025-12-29 03:03 , Processed in 0.015944 second(s), 4 queries , Gzip On, Redis On.
