查看: 27129|回复: 75
[资料] TCAD_Sentaurus_Lithography_PWA vD2009.12
发表于 2011-3-18 10:42:41 | 显示全部楼层 |阅读模式
Sentaurus Lithography PWA  is a process window analyzer. It is a comprehensive and powerful tool for visualizing and analyzing simulation results or experimental data, for example, obtained by critical dimension (CD) metrology measurements. From input data generally obtained from a focus-exposure matrix, PWA determines key measures that characterize the performance of the lithographic process, such as process window size or exposure latitude. Multiple datasets are analyzed individually, and the overlapping (or common) process window is determined.
PWA is a stand-alone software application designed specifically towards the analysis of CD metrology measurement data. All aspects of process window analysis functionality are also available within the Base Module of Sentaurus Lithography for standard evaluations of simulation results.
  • Enable fast and effective qualification of lithography process by flexible analysis of process windows and their properties
  • Support conditioning of measurement data (e.g. by smoothing or flyer elimination) to improve input data quality for subsequent data fitting in order to obtain more robust models (resist model parameter, OPC models, etc.)
  • Enable effective visualization of large and complex data sets
PWA is a general-purpose tool that can analyze any multidimensional matrix of
observations as a function of two parameters. These observations (input data)
are usually CDs of a series of features – measured or simulated – as a function of
exposure dose and defocus (deviation from a nominal focus position). Other typical
indicators can be sidewall angles of resist profi les or resist thickness loss
Features
1.Process Window Analysis
Perform rectangular or elliptical fit
of process windows under various
working-point conditions
Determine overlapping process
window for multiple datasets
Compute process latitude (PW graph)
2.Data Processing
Import measurement result files
from Hitachi and Applied Materials
metrology equipment
Filter noisy input data, detect outliers,
and reduce data volume
Perform statistical analysis of
measurement data
Visualize measurement data and
analysis results
3.General Features
Support link to Sentaurus Lithography
for analysis of simulation results
Enable integration and automation of
tasks through API functionality
4.Sentaurus Lithography – Modules and
Options
Base module
Optical module – Optical lithography
process simulation
MT module – Mask topography
simulation
WT module – Wafer topography
simulationEUV module – Extreme ultraviolet
lithography simulation
E-beam module – Electron-beam
MP option – Parallel computation
support
download:
TCAD_Sentaurus_Lithography_PWA vD2009.12.part02.rar
4.77 MB, 下载次数: 159 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2011-3-18 10:48:19 | 显示全部楼层
11111111111111
TCAD_Sentaurus_Lithography_PWA vD2009.12.part03.rar
4.77 MB, 下载次数: 140 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part01.rar
4.77 MB, 下载次数: 165 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2011-3-18 10:55:55 | 显示全部楼层
222222222222222222
TCAD_Sentaurus_Lithography_PWA vD2009.12.part07.rar
4.77 MB, 下载次数: 136 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part04.rar
4.77 MB, 下载次数: 142 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part05.rar
4.77 MB, 下载次数: 147 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part06.rar
4.77 MB, 下载次数: 150 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2011-3-18 11:05:50 | 显示全部楼层
333333333333333333
TCAD_Sentaurus_Lithography_PWA vD2009.12.part11.rar
4.77 MB, 下载次数: 133 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part08.rar
4.77 MB, 下载次数: 134 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part09.rar
4.77 MB, 下载次数: 125 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part10.rar
 楼主| 发表于 2011-3-18 11:16:01 | 显示全部楼层
444444444444444444444
TCAD_Sentaurus_Lithography_PWA vD2009.12.part16.rar
4.77 MB, 下载次数: 131 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part12.rar
4.77 MB, 下载次数: 126 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part13.rar
TCAD_Sentaurus_Lithography_PWA vD2009.12.part14.rar
4.77 MB, 下载次数: 127 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part15.rar
4.77 MB, 下载次数: 121 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2011-3-18 11:27:24 | 显示全部楼层
5555555555555555555555555
TCAD_Sentaurus_Lithography_PWA vD2009.12.part22.rar
4.77 MB, 下载次数: 108 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part17.rar
4.77 MB, 下载次数: 104 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part18.rar
4.77 MB, 下载次数: 109 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part19.rar
4.77 MB, 下载次数: 107 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part20.rar
TCAD_Sentaurus_Lithography_PWA vD2009.12.part21.rar
4.77 MB, 下载次数: 112 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2011-3-18 11:38:43 | 显示全部楼层
66666666666666666
TCAD_Sentaurus_Lithography_PWA vD2009.12.part28.rar
3.9 MB, 下载次数: 104 , 下载积分: 资产 -2 信元, 下载支出 2 信元
end
TCAD_Sentaurus_Lithography_PWA vD2009.12.part23.rar
4.77 MB, 下载次数: 106 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part24.rar
TCAD_Sentaurus_Lithography_PWA vD2009.12.part25.rar
4.77 MB, 下载次数: 115 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part26.rar
4.77 MB, 下载次数: 114 , 下载积分: 资产 -3 信元, 下载支出 3 信元
TCAD_Sentaurus_Lithography_PWA vD2009.12.part27.rar
 楼主| 发表于 2011-3-18 17:38:03 | 显示全部楼层
Add to .cshrc
            setenv SNPSLMD_LICENSE_FILE 27000@myserver
            or
            setenv LM_LICENSE_FILE 27000@myserver
Add to .profile, .kshrc, or .bashrc
            SNPSLMD_LICENSE_FILE=27000@myserver; export SNPSLMD_LICENSE_FILE
            or
            LM_LICENSE_FILE=27000@myserver; export LM_LICENSE_FILE
Add to .cshrc:
           set path=(synopsys_root/<platform>/<product>/bin $path)
Add to .profile, .kshrc, or .bashrc:
           PATH=synopsys_root/<platform>/<product>/binPATH
           export PATH
发表于 2011-3-25 15:47:27 | 显示全部楼层
这么多包啊……
发表于 2011-3-29 10:14:43 | 显示全部楼层
very good!!!!!
GMT+8, 2025-12-18 18:26 , Processed in 0.026827 second(s), 6 queries , Gzip On, Redis On.
