楼主: jimipage
[原创] delta sigma ADC 设计流程???
发表于 2011-3-13 16:39:01 | 显示全部楼层
Just some of my experience:
1. Synthesize the NTF according to the specifications using MATLAB;
2. Build the SDM topology in SIMULINK, and simulate including non-idealities;
3. Map the coefficients to R and C (continuous-time); or C array (discrete);
4. Build the SDM circuit using ideal SPICE micro-models (i.e an amplifier can be modeled as VCVG, and switched can be modeled as voltage controlled resistor);
5. Design each building block, and substitute into the macro-model circuits;
6. Eventually all circuit level is designed, and sweep the process corner.
 楼主| 发表于 2011-3-14 01:09:00 | 显示全部楼层
谢谢,SDMOUT
发表于 2011-7-18 18:57:09 | 显示全部楼层
回复 1# jimipage
  有具体指标吗,大体步骤:
1.完全清楚原理,以及你要采用的结构;
2.利用sdtoolbox综合NTF,首先确定各个系数,前馈或者反馈的;
3.行为仿真,得到大致的snr范围,如果电路设计的好,电路仿真结果就基本一致;
4.做电路,版图,仿真。
发表于 2013-1-4 13:31:13 | 显示全部楼层
Gooooooooooooood
发表于 2020-3-26 12:16:41 | 显示全部楼层
good, just learning SD ADC !!!
发表于 2021-12-3 20:35:53 | 显示全部楼层
thank you, 11# and 13#
发表于 2021-12-4 11:16:39 | 显示全部楼层
about this, you can ref Page 51, Chapter 10, EE315B for Sigma-delta ADC Design Flow
发表于 2021-12-27 17:20:46 来自手机 | 显示全部楼层
哥们,可以加个好友吗
发表于 2021-12-27 19:41:32 | 显示全部楼层
ztwd520 发表于 2021-12-27 17:20
哥们,可以加个好友吗
for what
发表于 2021-12-28 14:05:50 来自手机 | 显示全部楼层
任性 发表于 2021-12-27 19:41
for what
想请教一下sigma delta
GMT+8, 2025-12-30 04:29 , Processed in 0.018600 second(s), 4 queries , Gzip On, Redis On.
