查看: 11048|回复: 17
[求助] hspice 2010 的安装问题,求助,在线等啊,谢谢
发表于 2011-3-10 19:56:34 | 显示全部楼层 |阅读模式
Hspice_D-2010.03-SP1
*2-1.sp DC  Node  Voltage   Analysis
Is      0   1     DC        6A
Vs     4   0     DC        3V
R1     1   0               1
R2     3   0               2
R3     3   4               3
RL     1   3               1
.OP
.DC    Vs  3V    5V        1V
.PRINT  DC  V(1)  V(3)      V(1,3)
.END
****** HSPICE -- D-2010.03-SP1 32-BIT (May 26 2010) winnt ******
  Copyright (C) 2010 Synopsys, Inc. All Rights Reserved.
  Unpublished-rights reserved under US copyright laws.
  This program is protected by law and is subject to the
  terms and conditions of the license agreement from Synopsys.
  Use of this program is your acceptance to be bound by the
  license agreement. HSPICE is the trademark of Synopsys, Inc.
  Input File: f:\0510601-ch2\p2-5.sp
  lic:
  lic: FLEXlm: v8.5b
  lic: USER:   Administrator        HOSTNAME: OK6H4J9L18NB0SA
  lic: HOSTID: 001d60834fec         PID:      3340
  lic: Using FLEXlm license file:
  lic: 27000@elena
  lic: Checkout 1 hspice
  lic: License/Maintenance for hspice will expire on 31-dec-2020/2007.9
  lic: NODE LOCKED license on hostid 001d60834fec
  lic:
Init: read install configuration file: G:\synopsys\Hspice_D-2010.03-SP1\meta.cfg
******  option summary
runlvl  = 3         bypass  = 2
*2-1.sp dc node voltage analysis
  ******  dc transfer curves tnom=  25.000 temp=  25.000 *****
        volt    voltage      voltage      voltage
                     1            3            1
                                               3
    3.00000     375.0000m    750.0000m   -375.0000m
    4.00000     500.0000m      1.0000    -500.0000m
    5.00000     625.0000m      1.2500    -625.0000m
y
1****** HSPICE -- D-2010.03-SP1 32-BIT (May 26 2010) winnt ******
  ******  operating point information tnom=  25.000 temp=  25.000 *****
***** operating point status is all       simulation time is     0.
    node    =voltage      node    =voltage      node    =voltage
+0:1       = 375.0000m 0:3       = 750.0000m 0:4       =   3.0000
****  voltage sources
subckt
element  0:vs
  volts      3.0000
  current -750.0000m
  power      2.2500
     total voltage source power dissipation=    2.2500        watts
***** current sources
subckt
element  0:is
  volts   -375.0000m
  current    6.0000a
  power      2.2500a
     total current source power dissipation=   2.2500a       watts
**** resistors
subckt
element  0:r1       0:r2       0:r3       0:rl
  r value    1.0000     2.0000     3.0000     1.0000
  v drop   375.0000m  750.0000m   -2.2500  -375.0000m
  current  375.0000m  375.0000m -750.0000m -375.0000m
  power    140.6250m  281.2500m    1.6875   140.6250m
          ***** job concluded
  ******  job statistics summary tnom=  25.000 temp=  25.000 *****
  ******  HSPICE Threads Information  ******
  Command Line Threads Count                  :     1
  Available CPU Count                         :     2
  Actual Model Evaluation(Load) Threads Count :     1
  Actual Solver Threads Count                 :     1
  ******  Circuit Statistics  ******
  # nodes       =       4 # elements   =       6
  # resistors   =       4 # capacitors =       0 # inductors   =       0
  # mutual_inds =       0 # vccs       =       0 # vcvs        =       0
  # cccs        =       0 # ccvs       =       0 # volt_srcs   =       1
  # curr_srcs   =       1 # diodes     =       0 # bjts        =       0
  # jfets       =       0 # mosfets    =       0 # U elements  =       0
  # T elements  =       0 # W elements =       0 # B elements  =       0
  # S elements  =       0 # P elements =       0 # va device   =       0
  ******  Runtime Statistics (seconds)  ******
  analysis           time    # points   tot. iter  conv.iter
  op point           0.01           1           4
  dc sweep           0.00           3           8
  readin             0.05
  errchk             0.00
  setup              0.02
  output             0.00
           total memory used           27  kbytes
           total cpu time            0.09 seconds
           total elapsed time        0.12 seconds
           job started at     19:41:30 03/10/2011
           job ended   at     19:41:30 03/10/2011
  lic: Release hspice token(s)
不知道有没有错误,但是点击waveview时,说文件不存在。这是什么问题啊??
发表于 2011-3-11 09:00:27 | 显示全部楼层
xiexie
发表于 2011-3-11 10:12:32 | 显示全部楼层
仿真跑完了,没有问题。
看看目录下有没有*.sw*文件,因为你作的是直流分析。
发表于 2011-3-11 23:14:03 | 显示全部楼层
谢谢分享!
发表于 2011-3-12 11:16:55 | 显示全部楼层
不清楚
发表于 2011-3-12 18:13:03 | 显示全部楼层
解决了没有啊?
发表于 2011-3-12 19:23:12 | 显示全部楼层
回复 1# hyshentou
請加
.option post
這樣就會有.sw欓了
发表于 2011-3-14 10:53:40 | 显示全部楼层
对,楼上的正解
发表于 2011-3-14 21:42:15 | 显示全部楼层
同样的问题啊
发表于 2011-3-15 23:17:51 | 显示全部楼层
请问一下,这个问题解决了没有啊。我也装的2010 sp1版本,环境变量跟楼主也是一样。但是在hspui打开demo程序仿真后,再按waveview也出现了楼主这样的问题。。求解答@@@@@@@@@@@@
GMT+8, 2025-11-22 05:48 , Processed in 0.034782 second(s), 7 queries , Gzip On, Redis On.
