查看: 5030|回复: 0
[求助]关于open drain端口上拉电阻的设置?
发表于 2005-8-5 22:02:04 | 显示全部楼层 |阅读模式
open drain端口使用的上拉电阻驱动5V CMOS,电阻阻值多大合适啊?
我用的是Acex 1K30,VCCINT = 2.5V, VCCIO = 3.3V
AN107上面的资料,但是没有说明到底是多大的电阻?只是说不能太大也不能太小:
To pull the output of a low-voltage device up to the V
IH
(input high) level
of a 5.0-V CMOS device, use an open-drain pin driving a trace that is
pulled up to 5.0 V through an external pull-up resistor (see Figure 4).
Choose a pull-up resistor that is small enough for a sufficient signal rise
time, but large enough that it does not violate the I
OL
(output low)
specifications of devices driving that trace.
GMT+8, 2025-12-24 18:00 , Processed in 0.017643 second(s), 7 queries , Gzip On, Redis On.
