查看: 8854|回复: 42
[资料] [ebook]A CMOS Self-Powered Front-End Architecture
发表于 2011-2-23 10:46:05 | 显示全部楼层 |阅读模式
title:   A CMOS Self-Powered Front-End Architecture for Subcutaneous Event-Detector Devices: Three-Electrodes Amperometric Biosensor Approach
creator(s):   Jordi Colomer-Farrarons · Pere Lluís Miribel-Català
publisher:   Springer
publication year:   2011
A CMOS Self-Powered Front-End Architecture for Subcutaneous Event-Detector Devices presents the conception and prototype realization of a Self-Powered architecture for subcutaneous detector devices. The architecture is designed to work as a true/false (event detector) or threshold level alarm of some substances, ions, etc... that are detected through a three-electrodes amperometric BioSensor approach. The device is envisaged as a Low-Power subcutaneous implantable application powered by an inductive link, one emitter antenna at the external side of the skin and the receiver antenna under the skin. The sensor is controlled with a Potentiostat circuit and then, a post-processing unit detects the desired levels and activates the transmission via a backscattering method by the inductive link. All the instrumentation, except the power module, is implemented in the so called BioChip. Following the idea of the powering link to harvest energy of the magnetic induced link at the implanted device, a Multi-Harvesting Power Chip (MHPC) has been also designed.
abbr_6e559b50546a1e2074044bb3c395bfc5.pdf
6.81 MB, 下载次数: 269 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2011-2-23 11:21:56 | 显示全部楼层
thank you
发表于 2011-2-23 11:45:48 | 显示全部楼层
非常感谢。。
发表于 2011-2-23 20:42:10 | 显示全部楼层
thank you very much
发表于 2011-2-23 22:50:16 | 显示全部楼层
Thanks!
发表于 2011-2-23 23:59:17 | 显示全部楼层
thanks for sharing
发表于 2011-2-24 09:14:26 | 显示全部楼层
下来看看,谢谢。
发表于 2011-2-24 09:15:37 | 显示全部楼层
谢谢分享……
发表于 2011-2-24 19:36:45 | 显示全部楼层
学习学习
发表于 2011-2-25 06:49:54 | 显示全部楼层
good staff. green energy.
GMT+8, 2025-12-20 08:31 , Processed in 0.149461 second(s), 7 queries , Gzip On, Redis On.
