查看: 2795|回复: 0
sst 全新热卖
发表于 2006-10-17 14:24:29 | 显示全部楼层 |阅读模式
IS62WV1288BLL-55HLI        TSOP        ISSI        06+        10000                        ★hot in own stock
IS62WV1288BLL-55TLI        TSOP        ISSI        06+        8700                        ★hot in own stock
IS63LV1024-12T        SOP        ISSI        05+        2700                        ★hot in own stock
IS63LV1024L-10T        SOP        ISSI        06+        2700                        ★hot in own stock
IS63LV1024L-12JL        SOJ        ISSI        06+        2309                        ★hot in own stock
SST25LF040A-33-4I-S2AE        sop        SST        2004        2100                        ★hot in own stock
SST25LF080A-33-4C-S2A        sop        SST        2005        2000                        ★hot in own stock
SST25VF010-20-4C-SAE        sop        SST        2003        14000                        ★hot in own stock
SST25VF020-20-4C-QAE        lap        SST        2003        1500                        ★hot in own stock
SST25VF020-20-4C-SAE        lap        SST        2003        1900                        ★hot in own stock
SST25VF040-20-4C-S2AE        sop        SST        2006        12000                        ★hot in own stock
SST25VF040-20-4I-QAE        lap        SST        2004        1200                        ★hot in own stock
SST25VF512-20-4C-QAE        lap        SST        2003        1800                        ★hot in own stock
SST25VF512-20-4C-SAE        sop        SST        2005        5000                        ★hot in own stock
SST27SF020-70-3C-NHE        plcc        SST        2006        12000                        ★hot in own stock
SST28SF040A-120-4C-EH        tsop        SST        2002        15000                        ★hot in own stock
SST28SF040A-90-4C-EH        tsop        SST        2002        11000                        ★hot in own stock
SST28SF040A-90-4C-NH        plcc        SST        2004        2000                        ★hot in own stock
SST29EE010-90-4C-NH        plcc        SST        2005        5000                        ★hot in own stock
SST29EE010-90-4C-PH        dip        SST        2005        3200                        ★hot in own stock
SST29LE010-150-4C-NH        plcc        SST        2004        1600                        ★hot in own stock
SST29LE020-200-4C-EH        tsop        SST        2003        17000                        ★hot in own stock
SST29LE020-200-4C-NH        plcc        SST        2005        130                        ★hot in own stock
SST29SF040-55-4C-NHE        plcc        SST        2006        600                        ★hot in own stock
SST29SF040-55-4C-WH        tsop        SST        2005        1                        ★hot in own stock
SST29VF040-70-4C-NH        plcc        SST        2005        5                        ★hot in own stock
SST30VR023-500-C-KH        tsop        SST        2000        10000                        ★hot in own stock
SST31LF021E-300-4C-KH        tsop        SST        2000        5200                        ★hot in own stock
SST32HF164-70-4C-EK        tsop        SST        2003        6000                        ★hot in own stock
SST34HF1641-90-4C-LFP        bga        SST        2001        1000                        ★hot in own stock
SST36VF1601C-70-4I-EK        tsop        SST        2004        30000                        ★hot in own stock
SST37VF020-70-3C-NH        plcc        SST        2005        5                        ★hot in own stock
SST39LF400A-55-4C-EK        tsop        SST        2004        3500                        ★hot in own stock
SST39SF010A-70-4C-WHE        tsop        SST        2005        4000                        ★hot in own stock
SST39SF020A-70-4C-NH        plcc        SST        2006        3800                        ★hot in own stock
SST39SF020A-70-4C-WH        tsop        SST        2006        8000                        ★hot in own stock
SST39SF040-70-4C-PH        DIP        SST        04+        11000                        ★hot in own stock
SST39SF040-70-4C-PHE        dip        SST        2006        5000                        ★hot in own stock
SST39SF040-70-4C-WHE        tsop        SST        2005        8000                        ★hot in own stock
SST39VF010-70-4C-NH        plcc        SST        2006        2500                        ★hot in own stock
SST39VF010-70-4C-WH        tsip        SST        2005        30                        ★hot in own stock
SST39VF020-70-4C-NH        plcc        SST        2000        200                        ★hot in own stock
SST39VF020-70-4C-WHE        tsop        SST        2005        100                        ★hot in own stock
SST39VF040-70-4C-NH        plcc        SST        03+        8700                        ★hot in own stock
SST39VF040-70-4C-NHE        plcc        SST        06+        1540                        ★hot in own stock
SST39VF040-70-4C-WH        tsop        SST        05+        20800                        ★hot in own stock
SST39VF040-70-4C-WHE        tsop        SST        06+        1650                        ★hot in own stock
SST39VF080-70-4C-EI        sop        SST        2005        1200                        ★hot in own stock
SST39VF1601-70-4C-EKE        tsop        SST        2006        9000                        ★hot in own stock
SST39VF160-70-4C-EK        sop        SST        2004        1100                        ★hot in own stock
SST39VF3201-70-4C-EKE        sop        SST        2006        8000        12.3                ★hot in own stock
SST39VF400A-70-4C-EK        tsop        SST        2003        15000                        ★hot in own stock
SST39VF512-70-4C-NHE        plcc        SST        2006        4000                        ★hot in own stock
SST39VF512-70-4C-WHE        tsop        SST        2006        4200        5                ★hot in own stock
SST39VF6401-70-4C-EK        sop        SST        2004        24                        ★hot in own stock
SST39VF800A-70-4C-EK        tsop        SST        2005        10000                        ★hot in own stock
SST49LF002B-33-4C-NH        plcc        SST        2005        600                        ★hot in own stock
SST49LF004B-33-4C-NHE        plcc        SST        2003        260                        ★hot in own stock
SST49LF008A-33-4C-EI        tsop        SST        2003        2500                        ★hot in own stock
SST49LF020A-33-4C-NH        plcc        SST        2002        1300                        ★hot in own stock
SST49LF040-33-4C-NH        plcc        SST        2002        2000                        ★hot in own stock
SST55LD016TQW                SST        2005        8000                        ★hot in own stock
SST55LD017-40-C-TQW        qfp        SST        2001        8000                        ★hot in own stock
SST89E516RD2-40-C-NJ        plcc        SST        2005        8000                        ★hot in own stock
SST89E516RD-40-C-PI        dip        SST        2005        8000                        ★hot in own stock
SST89E54RD2-40-C-NJE        plcc        SST        2006        8000                        ★hot in own stock
SST89E554RC-40-C-NJ        plcc        SST        2005        8000                        ★hot in own stock
SST89E564RD-40-C-NJE        plcc        SST        2005        8000                        ★hot in own stock
SST89E564RD-40-C-PI        dip        SST        06+        4500                        ★hot in own stock
SST89E564RD-40-C-PIE        dip        SST        2005        8000                        ★hot in own stock
SST89E564RD-40-I-PIE        dip        SST        2006        8000                        ★hot in own stock
SST89E58RD2-40-C-NJ        plcc        SST        2005        3200                        ★hot in own stock
SST89E58RD-40-C-PIE        dip        SST        2006        4300                        ★hot in own stock
SST89V554RC-33-I-NJ        plcc        SST        2003        2000                        ★hot in own stock
Sample Text
GMT+8, 2025-12-27 20:26 , Processed in 0.017282 second(s), 7 queries , Gzip On, Redis On.
