楼主: domino.kk
[求助] DAC的问题
发表于 2011-1-21 23:28:32 | 显示全部楼层
Please refer to equation (11) in the classical paper of JSSC 1989 "Matching Properties of MOS Transistors" by Pelgrom.
You are supposed to get the MOS mismatch characterization report from foundry, which (at least) provides the key mismatch parameters "A_vt" and "A_beta."
Without these parameters, you don't know how much (Vgs - Vth) is sufficient.
A_vt (1-sigma of Vt0 mismatch, assuming W*L = 1 um^2)  for 0.35 um CMOS technology is a few mV/um.
(say, 5-7 mV)
A_beta (1-sigma of beta mismatch, assuming W*L = 1 um^2) for 0.35 um CMOS technology is roughly 1.2-1.5%.
From Pelgrom's equation you know in case you set high enough (Vgs - Vth), the contribution of Vth mismatch can be made less.
Then you can calculate the 1-sigma of unit-current source mismtaches based on A_vt, A_beta, (Vgs - Vth), W and L.
Remember you have 1,023 of such unit current devices, and DNL is the worst among these 1,023.
Suppose you want to get yield more than 99%.
Then your choice of (Vgs - Vth), W and L needs to guarantee mismatch causes error < 1 LSB (or even < 0.5 LSB, depending on how you set your design target). ...
Remember, the boundary of thermometer decode and binary-weighted decode is the worst case. ...
Owing to the fact your unit current is so small, my guts feeling says, even at 23.5 um channel length, the (Vgs - Vth) is still not large enough, (but I did not run simulations).
发表于 2011-1-22 07:57:02 | 显示全部楼层
回复 8# domino.kk
电源电压5V,用的是0.35um工艺,单位电流源的尺寸选择w=450nm,l=23.5um。这样可以保证一定的Vgs-Vth,不过我不知道一般要保证多大的Vgs-Vth,还有一个问题我不知道是不是开关电路部分出问题了还是怎么的,输出电路最后有很大的尖脉冲,尖脉冲全部出现在转换过程中。 ...
No need to check the waveform.
(Since you are using differential architecture,)
Two major factors contribute to glitches:
1. Whether your current sources are always maintained in saturation region (100% of the time),
Assume you have right-side switches, which direct current to the load, and you have left-side switches, which direct current to ground.  Your switch driver has to be carefully designed, and delay/load balanced.
(A) The signal delay from clock rising/falling edge to decoder outputs are well balanced.  (No matter what code is applied, the delay from clock edge to decoder outputs are almost identical.)
(B) Decoder driver is fine tuned, such that at the time right side switches are turned on (i.e., the current sources start to charge up the load), the left side switches are not completely turned off.  Thus there is a short period of time both sides divide the current from the current sources.  This scheme guarantees your current sources are 100% of the time maintained in saturation region.
2. How you determine how many bits are thermometer decoded, and how many are binary weighted decoded.
(I hope you are not using 100% binary weighted current sources.)  With ideal power and ground, you probably don't observe so huge the effect of factor two from simulation.
Assuming you are using 6-bit thermometer decode (MSB current source arrays), and 4-bit binary weighted (LSB) source sources.
LSB: 1X unit-current
2nd LSB: 2X unit current
3rd LSB: 4X unit current
4th LSB: 8X unit current
The rest 6 MSB's are thermometer decoded, so each MSB current source has 16X unit current, and you have 63 of such MSB current sources.
At first, your DAC input is 00,0000,1111.  All you LSB current sources are directed to the output.
None of your MSB surrent sources are selected and directed to the output.
The next time, your DAC input is 00,0001,0000.
None of your LSB current sources are directed to the load, and the 1st thermometer decoded MSB current source is directed to the output.
So the transition from 15 to 16 (decimal), we observe glitch due to switching of current source direction from (non-ideal) ground to the load.
So are the cases fom 31-32, 47-48, 63-64 transtions, and so forth.
If you use fully binary weighted current sources, at 511-512 transition, you observe the largest glitch. (I hope not.)
Your DNL also depends on how you determine # of MSB and # of LSB bits.
Then you to check whether (Vgs - Vth) is large enough to support the DNL you want.
(But this is another topic. ...)
Tip
  • Cascode reduces the noise coupling from decoder switching to the gate of current sources.
  • You may choose 3.3 V as the power supply level, to complete your 0.35 um 10-bit DAC design.  It is an easily achievable target, since you don't not have large output swing.
 楼主| 发表于 2011-1-22 16:48:33 | 显示全部楼层
回复 12# fhchen2002
    谢谢你写了那么多,问题是我的工艺是0.35um厚栅的,所以电源电压要5V
   然后我现在最头疼的是,如果我输出不接100K的负载,将来测试时岂不是无法测到信号,但是如果接了100K的电阻就会导致转换过程变慢,整个转换周期信号缓慢下降且无法进行一个LSB转换,另外如果使用了50的电阻转换过程正常了,但是就是在转换过程中出现相当大的毛刺脉冲,感觉问题就是出在开关电路部分,可是开关对我来说就是用了一个CMOS传输门,这点我现在仍然困扰着无法解决
发表于 2011-1-22 19:41:04 | 显示全部楼层
不敢说5nA,但是10nA应该能够做得出来,因为我就做了一个
 楼主| 发表于 2011-1-22 20:00:51 | 显示全部楼层
回复 14# sijutann
    有10nA也行呀,能留个QQ,MSN 或邮箱什么的吗?或者方便的话给些资料也行,我就是搞不定呀,万分感谢了,我最近被老板逼死了
发表于 2011-1-23 00:23:11 | 显示全部楼层
简单说下,输入5.12uA,分两级,通过不同开关控制的电流镜并联产生输出,第一级最小单位电流320nA,用运放控制电流镜两边的漏电压,这样精确,第二级320nA输入,最小10nA输出,然后第一级和第二级并到一起产生10nA精度的电流,注意电流镜的L越大越好,我的是3u,layout注意match。
发表于 2011-1-23 08:06:50 | 显示全部楼层
回复 13# domino.kk
Q: Did you check whether your current sources are always in saturation (with 100K load)?  Do you have "left-side" switches and "right-side" switches?
Q: Why didn't you consider nMOS switch?
再看一次:
(A) The signal delay from clock rising/falling edge to switch decoder outputs are well balanced.  (No matter what code is applied, the delay from clock edge to decoder outputs are almost identical.)
(B) Switch decoder driver is fine tuned, such that at the time right side switches are turned on (i.e., the current sources start to charge up the load), the left side switches are not completely turned off.  Thus there is a short period of time both sides divide the current from the current sources.  This scheme guarantees your current sources are 100% of the time maintained in saturation region.
If you use nMOS switches, you only have to make strong-P-weak-N switch driver to achieve (B).
 楼主| 发表于 2011-1-23 12:21:29 | 显示全部楼层
回复 16# sijutann
    还是不太懂,希望可以给个联系方式详细咨询下,或者给个电路图什么的,我是初学者,老板就交给这种任务,我还找不到什么资料,所以希望大大可以不吝赐教。
   我呢就比较简单的采用一个偏置电路产生两个偏置电压给共源共栅电流源提供栅极电压,然后数字部分就是分段译码电路,最后经锁存器产生控制信号给开关,控制电流源导通,然后开关采用的是CMOS传输门,但是现在总是产生很大毛刺,这是我的基本情况,能否教教我呢,谢谢啦
 楼主| 发表于 2011-1-23 12:44:43 | 显示全部楼层
回复 16# sijutann
    还有就是,你的两级变换是在做单位电流源的地方加入,还是做好一个5.12uA单位电流的DAC然后在输出端进行两级变换得到10nA单位电流的DAC,总之,希望能够进一步与你沟通
发表于 2011-1-23 19:30:44 | 显示全部楼层
回复 19# domino.kk
    上一张简单示意图,左边电流输入,中间电流第一级输出,右面作为第二级输入,两级结构一样。运放保证两端输入电压相等,电流能够精确镜像,80dB增益足够了。注意,开关的尺寸也要成比例。还有,我这个原理上是IDAC,但不作为DAC来用,电流的毛刺肯定有,在我这里是没有关系,所以对于你的设计仅供参考。
GMT+8, 2025-12-28 11:07 , Processed in 0.020598 second(s), 4 queries , Gzip On, Redis On.
