查看: 3390|回复: 6
need help for 64bit mmsim72
发表于 2011-1-1 22:48:57 | 显示全部楼层 |阅读模式
i download mmsim72 from ftp64
Using chenm001 patch, i can use 32 bit spectre correctly!
But i can not use 64bit spectre, can you give some advice or help?
Thanks
发表于 2011-1-2 20:28:57 | 显示全部楼层
Just set your environment by adding:
setenv CDS_AUTO_64BIT ALL
发表于 2011-1-8 17:53:19 | 显示全部楼层
can you please give me the link to the patch? also does the same patch work for IUS92?
发表于 2011-1-8 18:55:19 | 显示全部楼层
dingdingdingdingdingding
发表于 2011-1-19 19:38:17 | 显示全部楼层
学习了,但是不知道有没有成功呢?
发表于 2011-2-16 11:37:48 | 显示全部楼层
用32位的patch处理后,64位spectre也能用么?有谁try过啊
发表于 2015-8-20 20:21:12 | 显示全部楼层
回复 2# qin_hawk
   Thank you. This setting solved the issue for me.
GMT+8, 2025-12-21 10:43 , Processed in 1.038101 second(s), 8 queries , Gzip On, Redis On.
