台湾CIC教程,希望对大家有用!!!!
覆盖范围:
• CMOS versus Bipolar Implementation
• The Sub-micron MOS Transistor for Analog Design
• Small signal parameters for MOSFET Cut-off frequency, Concept of Poles and Zeros, Miller approximation
• Single stage Amplifiers Common source, Common gate, Source follower, Cascode
• Current Mirror Cascode Current Mirror, Wilson Current Mirror, Regulated Cascode
• Layout issues
•Differential Amplifier • Gilbert Cell
• Design of 2 stage CMOS OPAMP Differential to Single ended conversion, DC and AC response
Frequency Compensation, Pole Splitting, Zero Cancellation
•OPAMP Performance Metrics Slew rate, CMRR, Offset, Noise …
• Output Stage
• OTA and OPAMP Circuits
•Sample and Hold
•Switched Capacitor Circuits
• Bandgap Voltage Reference
• Sense Amplifier Voltage SA, Current SA, Latch type SA, Gain bandwidth analysis
• Comparator
• Impact of mismatch on Analog design Offset effects in Sense Amplifier
• Statistical Design and Simulation
• Alternate Device Gallery for Low Voltage Low Power Analog Design Wide common range OPAMP
Bulk driven OPAMP Lateral BJT in CMOS Technology
Sub-threshold operation of MOSFET : Neural Network Application Floating Gate transistor as analog memory |
