查看: 3120|回复: 6
[资料] Degrees of Freedom in Adaptive Modulation
发表于 2010-12-23 19:52:43 | 显示全部楼层 |阅读模式
We examine adaptive modulation schemes for flatfading
channels where the data rate, transmit power, and instantaneous
BER are varied to maximize spectral efficiency, subject to an
average power and BER constraint. Both continuous-rate and discrete-
rate adaptation are considered, as well as average and instantaneous
BER constraints.We find the general form of power, BER,
and data rate adaptation that maximizes spectral efficiency for a
large class of modulation techniques and fading distributions. The
optimal adaptation of these parameters is to increase the power
and data rate and decrease the BER as the channel quality improves.
Surprisingly, little spectral efficiency is lost when the power
or rate is constrained to be constant. Hence, the spectral efficiency
of adaptive modulation is relatively insensitive to which degrees of
freedom are adapted.
Degrees of Freedom in Adaptive Modulation.pdf
323.51 KB, 下载次数: 26 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-12-24 08:58:04 | 显示全部楼层
下来看看,谢谢。
发表于 2010-12-24 16:42:08 | 显示全部楼层
下来看看,谢谢。
发表于 2011-1-10 10:30:25 | 显示全部楼层
great, thanks
发表于 2011-6-5 12:50:09 | 显示全部楼层
多谢分享!!!!!!!
发表于 2011-6-6 11:01:47 | 显示全部楼层
下来看看,谢谢。
发表于 2016-9-27 17:22:03 | 显示全部楼层
thank you
GMT+8, 2025-9-20 00:18 , Processed in 0.027396 second(s), 6 queries , Gzip On, Redis On.
