查看: 28422|回复: 50
Libero 9.0的license
发表于 2010-12-6 22:12:25 | 显示全部楼层 |阅读模式
ACTEL官方的编辑软件
只需要将里面的硬盘号改为自己的就行了!
Golden ID.rar
6.62 KB, 下载次数: 855 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-12-6 22:13:28 | 显示全部楼层
说明:
Thank you for using Microsemi's Libero IDE software.
The attached license enables operation of Libero IDE Gold per the terms of the license agreement you accepted during your software installation.
Libero Gold now includes a feature line for Synplify Pro AE!
SEE THE NOTE AT THE BOTTOM OF THIS INSTRUCTION REGARDING USE OF SYNPLIFY PRO AE IN LIBERO IDE.
You should check the Hard Disk ID in this license file to be sure it matches the disk id of the target PC.
THIS LICENSE DOES NOT SUPPORT USE OF REMOTE DESKTOP.
NODE-LOCKED LICENSE INSTALLATION:
COPY ATTACHED FILE TO YOUR SYSTEM
1.  Create a folder named flexlm under your c: drive.
2.  Save the attached license.dat file in the flexlm folder. Alternately, you can save the license.dat in another folder in your c: drive. Be sure that you do not already have a license.dat file in this same directory that this could conflict with.
SET LM_LICENSE FILE AND SYNPLCTYD_LICENSE_FILE ENVIRONMENT VARIABLES
3.  Bring up Control Panel.
4.  Double click on 'System'.
5.  In the 'Systems Properties' dialog click on the 'Advanced' tab.
6.  Click on the 'Environment Variables' button.
IF LM_LICENSE_FILE IS ALREADY LISTED IN USER VARIABLES:
7.  Select it, then click 'Edit'.
8.  Add the path to the Actel license.dat file after any existing Variable Value, separated with a semicolon, or replace the existing Value. Be sure to retain the license.dat file name and extension at the end of the path.
Go to Step 11.
IF LM_LICENSE_FILE IS NOT LISTED IN USER VARIABLES:
7.  Click on the top most 'New' button. 'New User Variable' should be visible.
8.  In the 'Variable Name' field type: 'LM_LICENSE_FILE' (no quotes).
9.  In the 'Variable Value' field type: c:\flexlm\license.dat (or path to your license location).
10. Click OK.
ADD SYNPLCTYD_LICENSE_FILE TO USER VARIABLES: (NOTE: the correct spelling is SYNPLCTYD_LICENSE_FILE)
11. Click on the top most 'New' button. 'New User Variable' should be visible.
12. In the 'Variable Name' field type: 'SYNPLCTYD_LICENSE_FILE'(no quotes).
13. In the 'Variable Value' field type: 'c:\flexlm\license.dat'(no quotes).
14. Click OK.
15. Click OK to save new Environment Variables and return to System Properities. Click OK to exit.
AFTER INSTALLLING THIS LICENSE, FOLLOW THE STEPS BELOW TO USE SYNPLIFY PRO AE IN LIBERO IDE.
1.        OPEN Libero IDE.
2.        From the toolbar, click Project => Profiles
3.        The Profiles Dialog opens.
4.        Click on the 'Add' button, and select 'Synthesis'
5.        When the Add Profile Dialog opens, enter the name "Synplify Pro AE"
6.        On the 'Select a Tool For Integration' pull down, select "Synplify"
7.        In the Location window, browse to find and select 'synplify_pro.exe'. In a typical Libero IDE installation this will be c:\\Libero\Synplify\Synplify_version#\bin\synplify_pro.exe
8.        Click 'Open', and 'OK', 'OK' to save and close the Profile
9.        You should now be able to launch Synplify Pro.
For more information email tech@actel.com for assistance.
You can also refer to the Actel Libero IDE Installation and Licensing Guide under the User's Guides and Manuals section at
http://www.actel.com/techdocs/manuals/default.aspx
The Synopsys License Guide is located at http://www.actel.com/documents/synplicity_licensing_ug.pdf
发表于 2010-12-24 09:20:16 | 显示全部楼层
发表于 2010-12-25 09:52:39 | 显示全部楼层
can register and you will have libero Gold 1 year license
发表于 2011-1-22 11:06:34 | 显示全部楼层
多谢分享。试一试怎么样。
发表于 2011-1-25 09:50:57 | 显示全部楼层
要是有白金版的就好了!!!
发表于 2011-1-28 22:21:00 | 显示全部楼层
试验一下看看到底能不能用
发表于 2011-1-28 22:25:53 | 显示全部楼层
回复 1# suinibian2011
    只更改硬盘号不能使用阿,好像和软件id队不上阿
发表于 2011-1-29 16:39:14 | 显示全部楼层
Thanks
发表于 2011-6-24 09:58:38 | 显示全部楼层
貌似只改diskid不行呀
GMT+8, 2025-12-12 04:56 , Processed in 0.027464 second(s), 9 queries , Gzip On, Redis On.
