楼主: 900200
[暴力破解] Verdi 2010.10 of Linux 32-bit OS
发表于 2010-12-9 23:12:44 | 显示全部楼层
谢谢楼主分享!
发表于 2010-12-10 16:54:19 | 显示全部楼层
可以吗?
为什么我不行?
我替换了/bin和/platform/LINUX/bin目录下的,
ls -rtl /bin看一下
为什么好多命令都是链接到.wrapper呢?
verdi/nWave等都是同一个命令
发表于 2010-12-10 23:15:39 | 显示全部楼层
我的也不行,无法启动图形界面
发表于 2010-12-10 23:24:52 | 显示全部楼层
楼主能不能写的稍微详细点,要替换哪些目录下的文件
 楼主| 发表于 2010-12-11 01:09:24 | 显示全部楼层
回复 14# careful_uestc
    [update on 2010-1211   Godspeed(900200)]
Some young engineers ask me where to replace the [暴力破解]cracked files I upload. Sorry, I forgot to point the path on the crack readme because I thought most verdi users are senior engineers.If you are senior engineers you can understand easily. If you are young engineers, do not be afraid, you can see the explain shown as below :
2. replace the files with the  "cracked files for NOVAS 2010.xx (Linunx 32-bits)"
    in your
{installed verdi path}/platform/LINUX/bin
    for example:  my verdi installed path is /home/asic/EDA/Novas2010xx/
    and you just need to replace the  [暴力破解]cracked files I upload into
    /home/asic/EDA/Novas2010xx/platform/LINUX/bin
发表于 2010-12-11 13:09:39 | 显示全部楼层
回复 15# 900200
  可以启动,但是有些feature用不了,比如systemverilog program看不了,需额外的license
发表于 2010-12-16 07:33:35 | 显示全部楼层
所以听起来像是破解不完全?不过还是感谢楼主的分享...
发表于 2010-12-20 12:51:49 | 显示全部楼层
可否只出一個檔案....信元不足中
GMT+8, 2025-12-14 00:15 , Processed in 0.015789 second(s), 4 queries , Gzip On, Redis On.
