查看: 4615|回复: 3
S3C2410中断的问题(一直卡在0x18)
发表于 2006-10-10 20:07:51 | 显示全部楼层 |阅读模式
用Timer-0产生定时中断
可是一但发生中断后,就一直卡在0x00000018         b        HandlerIRQ 出不来
请教各位老大, HandlerIRQ要如何宣告阿?
才能对应到真正的地址
2410TESTinit.S
        GET option.s
        GET memcfg.s
        GET 2410addr.s
BIT_SELFREFRESH EQU        (1<<22)
re-defined constants
USERMODE    EQU         0x10
FIQMODE     EQU         0x11
IRQMODE     EQU         0x12
SVCMODE     EQU         0x13
ABORTMODE   EQU         0x17
UNDEFMODE   EQU         0x1b
MODEMASK    EQU         0x1f
NOINT       EQU         0xc0
;The location of stacks
UserStack        EQU        (_STACK_BASEADDRESS-0x3800)        ;0x33ff4800 ~
SVCStack        EQU        (_STACK_BASEADDRESS-0x2800)         ;0x33ff5800 ~
UndefStack        EQU        (_STACK_BASEADDRESS-0x2400)         ;0x33ff5c00 ~
AbortStack        EQU        (_STACK_BASEADDRESS-0x2000)         ;0x33ff6000 ~
IRQStack        EQU        (_STACK_BASEADDRESS-0x1000)        ;0x33ff7000 ~
FIQStack        EQU        (_STACK_BASEADDRESS-0x0)        ;0x33ff8000 ~
;Check if tasm.exe(armasm -16 ...@ADS 1.0) is used.
        GBLL    THUMBCODE
        [ {CONFIG} = 16
THUMBCODE SETL  {TRUE}
            CODE32
THUMBCODE SETL  {FALSE}
            MACRO
        MOV_PC_LR
            [ THUMBCODE
            bx lr
            mov        pc,lr
        MEND
            MACRO
        MOVEQ_PC_LR
            [ THUMBCODE
                bxeq lr
            moveq pc,lr
        MEND
            MACRO
$HandlerLabel HANDLER $HandleLabel
$HandlerLabel
        sub        sp,sp,#4        ;decrement sp(to store jump address)
        stmfd        sp!,{r0}        USH the work register to stack(lr does't push because it return to original address)
        ldr     r0,=$HandleLabel;load the address of HandleXXX to r0
        ldr     r0,[r0]         ;load the contents(service routine start address) of HandleXXX
        str     r0,[sp,#4]      ;store the contents(ISR) of HandleXXX to stack
        ldmfd   sp!,{r0,pc}     OP the work register and pc(jump to ISR)
        MEND
        IMPORT  |Image$$RO$$Limit|  ; End of ROM code (=start of ROM data)
        IMPORT  |Image$$RW$$Base|   ; Base of RAM to initialise
        IMPORT  |Image$$ZI$$Base|   ; Base and limit of area
        IMPORT  |Image$$ZI$$Limit|  ; to zero initialise
        IMPORT  Main    ; The main entry of mon program
        AREA    Init,CODE,READONLY
        ENTRY
        ;1)The code, which converts to Big-endian, should be in little endian code.
        ;2)The following little endian code will be compiled in Big-Endian mode.
        ;  The code byte order should be changed as the memory bus width.
        ;3)The pseudo instruction,DCD can't be used here because the linker generates error.
        ASSERT        EF:ENDIAN_CHANGE
        [ ENDIAN_CHANGE
            ASSERT  EF:ENTRY_BUS_WIDTH
            [ ENTRY_BUS_WIDTH=32
                b        ChangeBigEndian            ;DCD 0xea000007
            [ ENTRY_BUS_WIDTH=16
                andeq        r14,r7,r0,lsl #20   ;DCD 0x0007ea00
            [ ENTRY_BUS_WIDTH=8
                streq        r0,[r0,-r10,ror #1] ;DCD 0x070000ea
        b        ResetHandler
        b        HandlerUndef        ;handler for Undefined mode
        b        HandlerSWI        ;handler for SWI interrupt
        b        HandlerPabort        ;handler for PAbort
        b        HandlerDabort        ;handler for DAbort
        b        .                ;reserved
        b        HandlerIRQ        ;handler for IRQ interrupt
        b        HandlerFIQ        ;handler for FIQ interrupt
;@0x20
        b        EnterPWDN
ChangeBigEndian
;@0x24
            DCD        0xee110f10        ;0xee110f10 => mrc p15,0,r0,c1,c0,0
            DCD        0xe3800080        ;0xe3800080 => orr r0,r0,#0x80;  //Big-endian
            DCD        0xee010f10        ;0xee010f10 => mcr p15,0,r0,c1,c0,0
            DCD 0x0f10ee11
            DCD 0x0080e380
            DCD 0x0f10ee01
        [ ENTRY_BUS_WIDTH=8
            DCD 0x100f11ee
            DCD 0x800080e3
            DCD 0x100f01ee
        DCD 0xffffffff  ;swinv 0xffffff is similar with NOP and run well in both endian mode.
        DCD 0xffffffff
        DCD 0xffffffff
        DCD 0xffffffff
        DCD 0xffffffff
        b ResetHandler
;Function for entering power down mode
; 1. SDRAM should be in self-refresh mode.
; 2. All interrupt should be maksked for SDRAM/DRAM self-refresh.
; 3. LCD controller should be disabled for SDRAM/DRAM self-refresh.
; 4. The I-cache may have to be turned on.
; 5. The location of the following code may have not to be changed.
;void EnterPWDN(int CLKCON);
EnterPWDN
        mov r2,r0                ;r2=rCLKCON
        tst r0,#0x8                ;POWER_OFF mode?
        bne ENTER_POWER_OFF
ENTER_STOP
        ldr r0,=REFRESH
        ldr r3,[r0]                ;r3=rREFRESH
        mov r1, r3
        orr r1, r1, #BIT_SELFREFRESH
        str r1, [r0]                ;Enable SDRAM self-refresh
        mov r1,#16                   ;wait until self-refresh is issued. may not be needed.
0        subs r1,r1,#1
        bne %B0
        ldr r0,=CLKCON                ;enter STOP mode.
        str r2,[r0]
        mov r1,#32
0        subs r1,r1,#1        ;1) wait until the STOP mode is in effect.
        bne %B0                ;2) Or wait here until the CPU&Peripherals will be turned-off
                        ;   Entering POWER_OFF mode, only the reset by wake-up is available.
        ldr r0,=REFRESH ;exit from SDRAM self refresh mode.
        str r3,[r0]
        MOV_PC_LR
ENTER_POWER_OFF
        ;NOTE.
        ;1) rGSTATUS3 should have the return address after wake-up from POWER_OFF mode.
        ldr r0,=REFRESH
        ldr r1,[r0]                ;r1=rREFRESH
        mov r1,#16                   ;Wait until self-refresh is issued,which may not be needed.
0        subs r1,r1,#1
        bne %B0
        ldr         r1,=MISCCR
        ldr        r0,[r1]
        orr        r0,r0,#(7<<17)  ;Make sure that SCLK0:SCLK->0, SCLK1:SCLK->0, SCKE=L during boot-up
        str        r0,[r1]
        ldr r0,=CLKCON
        str r2,[r0]
        b .                        ;CPU will die here.
WAKEUP_POWER_OFF
        ;Release SCLKn after wake-up from the POWER_OFF mode.
        ldr         r1,=MISCCR
        ldr        r0,[r1]
        bic        r0,r0,#(7<<17)  ;SCLK0:0->SCLK, SCLK1:0->SCLK, SCKE->H
        str        r0,[r1]
        ;Set memory control registers
            ldr        r0,=SMRDATA
        ldr        r1,=BWSCON        ;BWSCON Address
        add        r2, r0, #52        ;End address of SMRDATA
0
        ldr        r3, [r0], #4
        str        r3, [r1], #4
        cmp        r2, r0
        bne        %B0
        mov r1,#256
0        subs r1,r1,#1        ;1) wait until the SelfRefresh is released.
        bne %B0
        ldr r1,=GSTATUS3         ;GSTATUS3 has the start address just after POWER_OFF wake-up
        ldr r0,[r1]
        mov pc,r0
        LTORG
HandlerFIQ      HANDLER HandleFIQ
HandlerIRQ      HANDLER HandleIRQ
HandlerUndef    HANDLER HandleUndef
HandlerSWI      HANDLER HandleSWI
HandlerDabort   HANDLER HandleDabort
HandlerPabort   HANDLER HandlePabort
IsrIRQ
        sub        sp,sp,#4       ;reserved for PC
        stmfd        sp!,{r8-r9}
        ldr        r9,=INTOFFSET
        ldr        r9,[r9]
        ldr        r8,=HandleEINT0
        add        r8,r8,r9,lsl #2
        ldr        r8,[r8]
        str        r8,[sp,#8]
        ldmfd        sp!,{r8-r9,pc}
; ENTRY
ResetHandler
        ldr        r0,=WTCON       ;watch dog disable
        ldr        r1,=0x0
        str        r1,[r0]
        ldr        r0,=INTMSK
        ldr        r1,=0xffffffff  ;all interrupt disable
        str        r1,[r0]
        ldr        r0,=INTSUBMSK
        ldr        r1,=0x7ff                ;all sub interrupt disable, 2002/04/10
        str        r1,[r0]
        [ {FALSE}
        ; rGPFDAT = (rGPFDAT & ~(0xf<<4)) | ((~data & 0xf)<<4);
        ; Led_Display
        ldr        r0,=GPFCON
        ldr        r1,=0x5500
        str        r1,[r0]
        ldr        r0,=GPFDAT
        ldr        r1,=0x10
        str        r1,[r0]
        ;To reduce PLL lock time, adjust the LOCKTIME register.
        ldr        r0,=LOCKTIME
        ldr        r1,=0xffffff
        str        r1,[r0]
            [ PLL_ON_START
        ;Configure MPLL
        ldr        r0,=MPLLCON
        ldr        r1,=((M_MDIV<<12)+(M_PDIV<<4)+M_SDIV)  ;Fin=12MHz,Fout=50MHz
        str        r1,[r0]
        ;Check if the boot is caused by the wake-up from POWER_OFF mode.
        ldr        r1,=GSTATUS2
        ldr        r0,[r1]
        tst        r0,#0x2
        ;In case of the wake-up from POWER_OFF mode, go to POWER_OFF_WAKEUP handler.
        bne        WAKEUP_POWER_OFF
        EXPORT StartPointAfterPowerOffWakeUp
;          ldr        r0,=SMRDATA
;        ldr        r1,=BWSCON        ;BWSCON Address
;        add        r2, r0, #52        ;End address of SMRDATA
;0
;        ldr        r3, [r0], #4
;        str        r3, [r1], #4
;        cmp        r2, r0
;        bne        %B0
            ;Initialize stacks
        bl        InitStacks
          ; Setup IRQ handler
        ldr        r0,=HandleIRQ       ;This routine is needed
        ldr        r1,=IsrIRQ          ;if there isn't 'subs pc,lr,#4' at 0x18, 0x1c
        str        r1,[r0]
        ;Copy and paste RW data/zero initialized data
        ldr        r0, =|Image$$RO$$Limit| ; Get pointer to ROM data
        ldr        r1, =|Image$$RW$$Base|  ; and RAM copy
        ldr        r3, =|Image$$ZI$$Base|
        ;Zero init base => top of initialised data
        cmp        r0, r1      ; Check that they are different
        beq        %F2
1
        cmp        r1, r3      ; Copy init data
        ldrcc        r2, [r0], #4    ;--> LDRCC r2, [r0] + ADD r0, r0, #4
        strcc        r2, [r1], #4    ;--> STRCC r2, [r1] + ADD r1, r1, #4
        bcc        %B1
2
        ldr        r1, =|Image$$ZI$$Limit| ; Top of zero init segment
        mov        r2, #0
3
        cmp        r3, r1      ; Zero init
        strcc        r2, [r3], #4
        bcc        %B3
    [ NOT:THUMBCODE
            bl        Main        ;Don't use main() because ......
            b        .
    [ THUMBCODE         ;for start-up code for Thumb mode
            orr        lr,pc,#1
            bx        lr
            CODE16
            b        .
            CODE32
;function initializing stacks
InitStacks
        ;Don't use DRAM,such as stmfd,ldmfd......
        ;SVCstack is initialized before
        ;Under toolkit ver 2.5, 'msr cpsr,r1' can be used instead of 'msr cpsr_cxsf,r1'
        mrs        r0,cpsr
        bic        r0,r0,#MODEMASK
        orr        r1,r0,#UNDEFMODE|NOINT
        msr        cpsr_cxsf,r1                ;UndefMode
        ldr        sp,=UndefStack
        orr        r1,r0,#ABORTMODE|NOINT
        msr        cpsr_cxsf,r1                ;AbortMode
        ldr        sp,=AbortStack
        orr        r1,r0,#IRQMODE|NOINT
        msr        cpsr_cxsf,r1                ;IRQMode
        ldr        sp,=IRQStack
        orr        r1,r0,#FIQMODE|NOINT
        msr        cpsr_cxsf,r1                ;FIQMode
        ldr        sp,=FIQStack
        bic        r0,r0,#MODEMASK|NOINT
        orr        r1,r0,#SVCMODE
        msr        cpsr_cxsf,r1                ;SVCMode
        ldr        sp,=SVCStack
        ;USER mode has not be initialized.
        mov        pc,lr
        ;The LR register won't be valid if the current mode is not SVC mode.
        LTORG
 楼主| 发表于 2006-10-10 20:08:07 | 显示全部楼层
SMRDATA DATA
; Memory configuration should be optimized for best performance
; The following parameter is not optimized.
; Memory access cycle parameter strategy
; 1) The memory settings is  safe parameters even at HCLK=75Mhz.
; 2) SDRAM refresh period is for HCLK=75Mhz.
        DCD (0+(B1_BWSCON<<4)+(B2_BWSCON<<8)+(B3_BWSCON<<12)+(B4_BWSCON<<16)+(B5_BWSCON<<20)+(B6_BWSCON<<24)+(B7_BWSCON<<28))
            DCD ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC))   ;GCS0
            DCD ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC))   ;GCS1
            DCD ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC))   ;GCS2
            DCD ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC))   ;GCS3
            DCD ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC))   ;GCS4
            DCD ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC))   ;GCS5
            DCD ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN))    ;GCS6
            DCD ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN))    ;GCS7
            DCD ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+(Tchr<<16)+REFCNT)
        DCD 0x32            ;SCLK power saving mode, BANKSIZE 128M/128M
            DCD 0x30            ;MRSR6 CL=3clk
            DCD 0x30            ;MRSR7
;            DCD 0x20            ;MRSR6 CL=2clk
;            DCD 0x20            ;MRSR7
            ALIGN
                AREA RamData, DATA, READWRITE
        ^   _ISR_STARTADDRESS
HandleReset         #   4
HandleUndef         #   4
HandleSWI           #   4
HandlePabort    #   4
HandleDabort    #   4
HandleReserved  #   4
HandleIRQ           #   4
HandleFIQ           #   4
;Don't use the label 'IntVectorTable',
;The value of IntVectorTable is different with the address you think it may be.
;IntVectorTable
HandleEINT0           #   4
HandleEINT1           #   4
HandleEINT2           #   4
HandleEINT3           #   4
HandleEINT4_7        #   4
HandleEINT8_23        #   4
HandleRSV6        #   4
HandleBATFLT           #   4
HandleTICK           #   4
HandleWDT        #   4
HandleTIMER0         #   4
HandleTIMER1         #   4
HandleTIMER2         #   4
HandleTIMER3         #   4
HandleTIMER4         #   4
HandleUART2          #   4
HandleLCD         #   4
HandleDMA0        #   4
HandleDMA1        #   4
HandleDMA2        #   4
HandleDMA3        #   4
HandleMMC        #   4
HandleSPI0        #   4
HandleUART1        #   4
HandleRSV24        #   4
HandleUSBD        #   4
HandleUSBH        #   4
HandleIIC           #   4
HandleUART0         #   4
HandleSPI1         #   4
HandleRTC         #   4
HandleADC         #   4
        END
 楼主| 发表于 2006-10-11 19:45:05 | 显示全部楼层
不求人..搞定
发表于 2007-3-27 13:57:47 | 显示全部楼层
请教
你的问题如何解决
GMT+8, 2025-12-18 16:46 , Processed in 0.020017 second(s), 6 queries , Gzip On, Redis On.
