查看: 3190|回复: 4
[招聘] 经典IC设计面试问题3
发表于 2010-11-27 12:18:30 | 显示全部楼层 |阅读模式
Tell me about verilog  file I/O?
OPEN A FILE
integer file;
file = $fopenr("filename");
file = $fopenw("filename");
file = $fopena("filename");
The function $fopenr opens an existing file for reading. $fopenw opens a new file for writing, and $fopena opens a new file for writing where any data will be appended to the end of the file. The file name can be either a quoted string or a reg holding the file name. If the file was successfully opened, it returns an integer containing the file number (1..MAX_FILES) or NULL (0) if there was an error. Note that these functions are not the same as the built-in system function $fopen which opens a file for writing by $fdisplay. The files are opened in C with 'rb', 'wb', and 'ab' which allows reading and writing binary data on the PC. The 'b' is ignored on Unix.
CLOSE A FILE
integer file, r;
r = $fcloser(file);
r = $fclosew(file);
The function $fcloser closes a file for input. $fclosew closes a file for output. It returns EOF if there was an error, otherwise 0. Note that these are not the same as $fclose which closes files for writing.
发表于 2010-12-5 21:19:25 | 显示全部楼层
That's right 多谢楼主分享!
发表于 2010-12-19 23:03:39 | 显示全部楼层
kanyixia
发表于 2011-1-1 20:11:54 | 显示全部楼层
学习了
发表于 2011-1-20 18:44:10 | 显示全部楼层
有这样的函数么$fopenr,我怎么不知道啊
GMT+8, 2025-12-19 04:28 , Processed in 0.026441 second(s), 6 queries , Gzip On, Redis On.
