查看: 2144|回复: 1
[原创] 求:一篇文章,谢谢
发表于 2010-11-15 21:53:16 | 显示全部楼层 |阅读模式
Miller compensation using current buffers in fully differential CMOS two-stage operational amplifiers
Hurst, P.J.;   Lewis, S.H.;   Keane, J.P.;   Aram, F.;   Dyer, K.C.;
Dept. of Electr. & Comput. Eng., Univ. of California, Davis, CA, USA
This paper appears in: Circuits and Systems I: Regular Papers, IEEE Transactions on
Issue Date: Feb. 2004
Volume: 51 Issue:2
On page(s): 275 - 285
ISSN: 1549-8328
INSPEC Accession Number: 8006172
Digital Object Identifier: 10.1109/TCSI.2003.820254
Date of Current Version: 13 四月 2004
Sponsored by: IEEE Circuits and Systems Society
Abstract
Several Miller compensation schemes using a current buffer in series with the compensation capacitor to modify the right-half-plane zero in fully differential two-stage CMOS operational amplifiers are analyzed. One scheme uses a current mirror as a current buffer, while the rest use a common-gate transistor as a current buffer. The gain transfer functions are derived for each topology, and approximate transfer-function coefficients are found that allow accurate estimation of the zero(s) and poles.
发表于 2010-11-16 11:10:30 | 显示全部楼层
abbr_2a3eed3acfd5c9831470f37761b4f800.pdf
322.15 KB, 下载次数: 6 , 下载积分: 资产 -2 信元, 下载支出 2 信元
GMT+8, 2025-12-31 00:41 , Processed in 0.026268 second(s), 7 queries , Gzip On, Redis On.
