查看: 2998|回复: 6
[招聘] 【招聘】全球著名硬件公司LSI上海研发中心职业发展机会(全)
发表于 2010-11-12 14:03:25 | 显示全部楼层 |阅读模式
LSI公司简介-上海研发中心位于徐汇区徐汇苑大厦,深圳办公室位于帝国大厦
LSI公司成立于1981年,总部设在美国硅谷。LSI在全球拥有5000多名员工,在20几个国家和地区设有分公司,在中国拥有上海、北京、深圳、香港、台湾等分支机构。拥有强大的产品研发、销售、市场、技术服务队伍。LSI公司是创新芯片、系统和软件技术的领先供应商,采用LSI技术的产品可以使消费者与信息及数码内容之间无缝的融合。
公司在众多领域提供产品和服务,包括定制标准芯片、适配器、系统和软件。我们的产品已经获得众多世界级知名品牌的信任,为存储和网络市场提供了许多领先的解决方案。
欢迎有志之士加入!如有任何疑问,请发送邮件至Tracey.zheng@lsi.com或拨打电话021-24191709.也可加我msn;zql975504@hotmail.com
有意者,请将简历发至:Tracey.zheng@lsi.com
1.
Preamp Analog/Mixed Signal Design Engineer-Shanghai
JOB DESCRIPTION:
- Design high speed analog and mixed-signal integrated circuits within custom chips for the
hard disk drive industry
- Work directly with customers to determine system requirements, write specifications and
guide customers in the use of pre-amplifier products
- Use high speed electronic characterization equipment to evaluate and debug the
functionality of the design once the part is fabricated in silicon
- Provide technical leadership through all phases of product development including test,
yield, characterization, reliability analysis, qualification and release to manufacturing
PREFERRED EXPERIENCE:
LSI's Storage Peripherals Group is looking for an experienced custom analog IC designer to
join the pre-amplifier design team. At LSI we are committed to innovation and industry
leadership. We develop advanced high-speed magneto electronic read/write IC architectures
as the basis for our products.
Design team members define, create and modify high-speed custom integrated circuits for
hard disk drive (HDD) products using leading edge CMOS and SiGe BiCMOS technologies.
Team members support the entire product life cycle beginning with design and moving through
test, qualification, release to production and ramp to volume.
- Degree in Electrical Engineering (or related field), MS required, Ph.D. preferred
- Minimum three to five years experience in discrete, transistor level analog circuit design
- Experience with analog and mixed signal IC product design, integration and verification is
required
- Strong physical layout knowledge and parasitic component understanding essential
- Process and device physics knowledge critical
- Proven skills using electronic measurement equipment in a lab environment
- Expertise in applied magnetism and recording a strong plus
2.
Digital IC Design Engineer-Shanghai
JOB DESCRIPTION:
- Working with an Architecture/Algorithm Development Team to finalize system architecture
for optimal implementation of digital signal processing algorithms, including architectural
definition and tradeoffs, die size estimation.
- Digital logic design, verilog coding, logic synthesis, both RTL and gate level verification,
formal verification and static timing analysis.
- Perform some transistor level high speed digital integrated circuit design various cells and
blocks within custom chips for the hard disk drive industry. Examples of cells and blocks
include multiplexors, adders, multipliers, dividers, specific functional macro blocks,
- Work very closely with physical design engineers from floorplan through final parasitic
extraction to ensure smallest area and highest performance possible.
- Communicate effectively within a global business environment (must be proficient in both
spoken and written English)
- Experience in logic design, synthesis, static timing analysis, and verification
- Experience with ASIC EDA tools used in synthesis, simulation, static timing analysis, and
formal verification
- Experience in developing simulation and verification test benches
- Knowledge of Verilog/VHDL design languages
- Excellent technical troubleshooting and demonstrated problem solving skills
- Must be willing to follow a structured design approach including design for reuse and
provide thorough design documentation
3.
Read Channel Verification Engineer-Shanghai
JOB DESCRIPTION:
As a member of the Read Channel team, candidate must be willing to work as an extended
member of the design team. Duties will include functional verification of Storage read
channel mixed-signal IP. Candidate will be expected to contribute to design and development
of System Verilog based verification environment and will be responsible for verification
closure of block/chip/system level functions for mixed signal based IP. Experience with
System Verilog and functional coverage methodologies are required. Must be willing to
follow a disciplined verification methodology and to work closely with a multi-location,
international design team. Excellent teamwork and communication skills are required.
BSEE with 3-5+ years of design and/or verification experience required, MSEE preferred.
Required knowledge and skills:
- Expertise in System Verilog required
- Good understanding of Digital Signal Processing
- Good understanding of Analog and Digital Circuits
- Very good analytical/debugging skill
- Good verbal and written communication skills
Desirable skills:
- Knowledge of Verilog-AMS, Perl
- Knowledge of verification methodologies including functional coverage and constrained
random testing
- Knowledge of VLSI design flows & DFT
- Familiarity of high level programming language
- Experience working with globally distributed team management
- Experience in Supervising and mentoring Validation engineers
4.
Senior Verification Engineer-Shanghai
JOB DESCRIPTION:
Duties will include working with a Verification Team to develop reusable block and system level
verification environment using high level verification language to support
ASIC development.
Review RTL architectural and implementation specifications. Develop test plan, create stimulus drivers,
monitors, reference models, scoreboards, protocol checkers to verify
function and performance of advanced multiprotocol networking ASICs.
Define and develop application tests required to verify ASICs meet functional and performance goals.
Define and implement functional coverage plans.
Define and implement code coverage plans. Develop testing and regression
methodologies for new verification flow.
Coordinate test plan implementation and
regressions with remote team.
Incorporate reusability into all aspects of the verification environment.
Develop/maintain/enhance environment tools/scripts/makefiles.
Functional/Industry Knowledge:
Required:
- Minimum of 4-6 years ASIC verification experience in a product development environment
- Proven ASIC Design Verification skills
- Proficient with high level verification languages such as System Verilog and Specman e.
- Knowledge of data and telecommunication networking
- Proficient with one or more scripting languages, such as Shell, Perl and TCL.
- Superior debugging skills for large ASIC designs
- Strong written and verbal communication skills
- Adaptable to evolving customer requirements
- Experience in a lead position giving guidance to other engineers, tracking and overseeing
development progress.
Education/Certifications:
Required Degree: BS
Preferred Degree: MS
Preferred Major: Electrical Engineering or related discipline
5.
Verification Design Engineer-Shanghai
JOB DESCRIPTION:
Responsible for Design, Verification and customer support of protocol systems. Good
knowledge of High Speed Interconnects, Storage and Networking Protocols, such as PCI
Express, Ethernet, Fibre Channel, Serial RIO, Interlaken. Good communication skill is must.
Experience with FPGA prototyping/validation a plus.
Good knowledge of High Speed Interconnects, Storage and Networking Protocols, such as
PCI Express, Ethernet, Fibre Channel, Serial RIO, Interlaken. Good communication skill is
must. Experience with FPGA prototyping/validation a plus.
Design skills:
- Micro-architecture development & RTL Design
- Synthesis & Timing analysis
Verification skills:
- Verification, including development of methodologies, test plans, compliance test suite, test
bench & test cases, using System Verilog, Vera and Specman.
- Development of Bus Functional models (BFMs), transactors, assertions, and manage
coverage and regressions
Standards development:
- Work with standards bodies such as IEEE and PCI SIG to develop industry standard
specification for next generation product
Must be conversant with the following:
– Verilog, System Verilog, C++, EDA CAD tools,
– Synthesis, Timing constraints and Logic Equivalence
MSEE with 10+ years of relevant experience in a semiconductor industry.
6.
Design Validation Engineer-Shanghai
JOB DESCRIPTION:
- Set up bench test equipment and perform characterization measurements on high speed
mixed signal IC's, paying careful attention to measurement accuracy and repeatability and
test condition coverage
- Develop automated scripts and program test equipment to automate data collection and
report generation. Where automated measurements are not practical, manual data collection
is to be performed
- Work with design and other characterization teams in design verification and characterization
and errata corrective action, as well as work with program management, test and product
engineering to insure timely delivery of fully verified silicon
- Develop / Improve measurement accuracy and techniques and test condition coverage
- Support bench application engineers with in-depth customer specific measurements and
failure analysis
- Design and layout evaluation PCBs, paying careful attention to high speed signals and board
/ component parasitic
- Organize bench data into technical reports for reference and presentation. Presentation of
data to both internal and external customers
Requirements/Qualifications (Education):
- Investigative and analytical mindset, with a strong interest in electronics and technical work
- A thorough knowledge of electronic circuits and systems with practical experience in
analogue and digital electronic circuit design and debug
- Knowledge and experience in measurement accuracy and high speed measurements
techniques. Experience in RF measurement techniques is a plus
- Experience in operating and programming test and measurement equipment
- Experience in visual basic or similar programming language
- Good communication skills, especially in technical writing and reporting
- Bachelor in Electronics Engineering
7.
High-Speed Analog PCB Design Engineer-Shanghai
JOB DESCRIPTION:
LSI Corporation is a leading provider of innovative silicon, systems and software technologies that enable products which seamlessly bring people, information and digital content together.
This position is part of the LSI's world-lead head-to-host recording system design validation team, and focus on high speed pre-amplifier validation PCB design. The tasks include: perform PCB design & layout process (starting from schematics level to bring the layout to final completion of checking LVS and DRC), manufacture support, debugging of the PCB board, and basic high speed test.
· Bachelor or Master degree in Electronics/Electrical Engineering with minimum 5 years of high speed PCB design
· Demonstrated ability to design controlled impedance paths for high speed signal(single and differential, 4GHZ +) including tapping to chip unit for lineout.
· Good hands on knowledge of Altium tools. Experience with PCAD or Cadence Allegro design tool is also desired. And circuit analysis simulation tool in signal integrity is a plus.
· Deep understanding of manufacturing, flip chip soldering and mounting processes for PCB
· Fundamental knowledge on high speed test knowledge (e.g. TDR, s-parameter, De-Embedding methodology), transmission line theory and circuit analysis is required.
· Proven skills using electronic measurement equipment in a lab environment
· Expertise in applied magnetism and recording a strong plus
· Good oral and written communications in English skills are required
8.
Test Engineer-Shanghai
JOB DESCRIPTION:
- To support prototype and production releases of new products. Manage debug of test
program and hardware and meet product release schedules.
- Support test program development for implementing changes in new test methodologies
for test coverage improvement.
- Pursue Design for Test initiatives to optimize testability and achieve test cost reduction via
test time reduction and multiple site test solutions for production release.
- Support test chip test development and characterization of new IP used in LSI products.
- University graduate students with top scores in GPA
- Prior working experiences in the semiconductor industry field, specially in either IDM,
Fabless, or Foundry environment
- ATE programming skills would be essential (ATE platform: HP93k, J750…..)
- C++ and/or Perl programming skills
9.
DSP-System Application Engineer-Shanghai
Job Description
This is a software System Application Engineer position that involves supporting our latest
generation of DSP solutions for media gateway, baseband, and video applications. This engineer
will work directly with local customers to assist with porting, integration and debugging of various
software modules. Customer interaction includes both pre-sales activities and issue debugging
during development phases. Ability to work well with a variety of people and disciplines is
required. Frequent travel to customer sites is expected. Excellent communications skills in both
Chinese and English are required.
- At least 4 years of experience with DSP application design and development_
- Strong Knowledge on Media Gateway, VOIP or wireless baseband_
- Direct design experience on codec_
- Knowledge of code optimization_
- Knowledge of protocols such as TCP/IP, SIP, RTP_
- Embedded software development/debug experience_
- Teamwork, dedication, strong communications and interpersonal skills are critical._
- Fluent English and Mandarin _
Desired:_
- Experience with media gateways, cellular baseband or video transcoding_
- Specific experience with ARM processors and/or StarCore DSPs_
- Previous interaction with major telecom chip vendors in China_
Education/Certifications_
- Required Degree: BS_
- Preferred Degree: MS_
- Preferred Major: Electrical Engineering, Computer Science, or related disciplines
10System Applications Engineer -Shanghai
Job Description
This is a Software Systems Applications Engineering position that involves the development and support of reference applications and API/FPI software for our customers. Software development includes creation of applications software for LSI multicore processor configurations using runtime API software, development of data path processing and forwarding software. Software support includes providing technical help on integrating LSI supplied application software with customer systems, LSI supplied SDE (Software Development Environment), reviewing customer application code, creating debugger APIs, simulator maintenance, and contributing to system software API testing. Customer interaction includes both pre-sales activities and issue debugging during development phases. Ability to work well with a variety of people and disciplines is required. Travel to customer sites is expected. Excellent communications skills in both Chinese and English are required
- Minimum of 5 years software Engineering experience in a data networking or telecom product development. Focused on multicore processor microcode and API device driver with C on RTOS(Linux, VxWorks)
- Familiar with network architectures and applications, traffic management and resource management algorithms and function
- Knowledge of multicore processor and wireline (ATM, TCP/IP, MPLS, PPP, Gigabit/Fast Ethernet), wireless (NodeB, RNC, GGSN) networking protocols
- Familiar with Linux and VxWorks OS
- Excellent problem solving and communication skills
- Experience with writing documents (data-sheet, application-notes, etc.)
Desired: - software/hardware experience in Network Processor and/or multicore processor, e.g. PowerPC - customer support experience - knowledge of interface,e.g. PCI-E bus, GE, RapidIO Education/Certifications Required Degree: BS Preferred Degree: MS Preferred Major: MSEE or MSCS
11
Physical Design Engineer-Shanghai
JOB DESCRIPTION:
Strong individual contributor needed to support product line growth The candidate will work on leading edge storage solutions in full custom environment. The ideal candidate will have demonstrated experience/exposure to full custom high-speed analog physical design from design handoff through manufacturing, as well as full custom methodology development. Excellent communication skills are needed, as existing teams span multiple locations.
High level of physical design experience required. Expertise in full custom analog layout, signal integrity, power and electro-migration analysis, design rule and connectivity verification is required. Familiarity with digital physical design, basic circuit designs, manufacturing and IC packaging is required. Must be technically adept, a strong team player, ability to manage multiple priorities and have excellent interpersonal and communication skills.
12.
Assembly Manager-Shanghai
JOB DESCRIPTION:
Based in LSI Hsin Chu science based industrial park office. Working with world leading OSAT
partners in fast growing ASIA operation team.
Assembly and Bumping engineering and operational management include:
- New package and product characterization, qualification and implementation
- Packaging process improvement, alternative material and cost reduction
- Excursion and operation performance improvement
- Cross-organization functional coordination between package development, product
engineering, supply chain, quality and subcontractors
- MS or above in Electric / Electronic engineering, Physics, Chemistry, Material science
- 10+ year hands on experience in assembly and bumping operation
- Oversea management experience on direct OSAT subcontractors and system level customers
- Self motivated with strong work ethics
- Excellent negotiation skills
- Excellent communication skills in both Chinese and English
- Project management, DOE, 6Sigma
- _
13.
Field Application Engineer-Shenzhen
Job Description
• Work closely with Sales and customers to provide excellent support of new and existing
business, including pre-design win and post design win.
• Achieve design wins at customers
• Support customers on-site when needed.
• Work closely with global technical colleagues (USA, China) to provide backup support.
• Track issues and defects and drive to resolution.
• Provide quick response to key customer’s request on technical support.
• Provide technical training to Sales team and customers.
Specific Knowledge/Experience
• 5 years+ of experience with Storage controller, Storage system.
• Knowledge and experience in SAS Firmware/Software, Fiber Channel and SAS server system
• Experience using or supporting storage products eg. SAS processor/Controller/Expander or
storage system
• Broad Network or Storage knowledge
• Demonstrated ability to learn technology quickly
• Very good English communication skills
• Team player, self-motivation
• Communication/Information Systems or EE degree, Masters preferred
14.
Test Integration Optimization-Zhuhai
Job Description
Your responsibilities will include but not be limited to: Maintain testing processes, equipment and software to test disk array products in a manufacturing environment. Driving testing cycle time reduction. Work with TDE/design community to maintain/implement appropriate test methods in production. Provide support to technical staff in determining root cause of system failures and driving appropriate corrective action through test enhancements, design changes or process modification to prevent defects in disk array components. Also provide guidance to design community (software and hardware) on Design for Manufacturability (DFM) and Design for Testability (DFT) and Built-in Self Test (BIST) as well as maintaining and promoting test strategy development consistent with technology changes. The ideal candidate will have 5 or more years of experience in the following areas: 1. Use of oscilloscopes, logic analyzers and bus dis-assemblers. 2. Software maintenance/development in Java, 'C' or C++ for PC, Unix and Intel microprocessors 3. Microsoft Office suite of PC applications - primarily Excel and Word 4. Manufacturing assembly and test methods. 5. Knowledge of disk drive technology and operation, specifically Fiber Channel devices and SAS / SATA devices 6. International travel required.
(1) BS Computer Eng, Electrical Eng, or Computer Science.
(2) 5+ years experience in engineering, manufacturing test development, or related position for storage controllers, servers, or similar systems.
(3) Experience with being able to remotely address and coordinate test releases, issues or NPI (New Product Introduction) in cooperation with outsourced design suppliers and Contract Manufacturers (CM's) preferred
(4) Experience with and knowledge of server architecture, CPUs, memories, PCI bus, I2C bus, serial I/F, Ethernet I/F, and storage IO I/Fs (e.g. SAS, iSCSI, FC).
(5) Knowledge & experience of the Linux OS and programming experience in C and C++ required and Java is preferred.
(6) Experience in maintaining/optimizing diagnostics and test functions for HW listed above.
(7) Excellent written and verbal communications skills in English and Chinese. (8) Good problem solving and process troubleshooting skills
发表于 2010-11-13 11:22:37 | 显示全部楼层
发表于 2010-11-13 12:54:57 | 显示全部楼层
LSI  好像天天招人啊
 楼主| 发表于 2010-11-19 10:44:20 | 显示全部楼层
LSI 上海研发中心正在扩张中,所以确实有很多需求。
发表于 2010-11-21 10:44:48 | 显示全部楼层
LSI需求真这么大么?天天有新职位?很多网站都能看到招人信息,周围有些人去面过,也没看到有人过去。
发表于 2010-11-24 17:54:40 | 显示全部楼层
lsi有多少R&D
发表于 2010-11-26 15:16:04 | 显示全部楼层
应届生招不?看都是3到5年经验啊。。。
GMT+8, 2025-12-22 11:34 , Processed in 0.027436 second(s), 9 queries , Gzip On, Redis On.
