楼主: dainv
[资料] Analog Layout Synthesis: A Survey of Topological Approaches
发表于 2010-10-28 21:08:20 | 显示全部楼层
回复 10# totalsea
发表于 2010-10-28 21:18:35 | 显示全部楼层
谢谢分享~
发表于 2010-11-3 23:25:41 | 显示全部楼层
thank you
发表于 2010-12-27 01:17:12 | 显示全部楼层
Part I Placement
1 Device-Level Topological Placement with Symmetry Constraints. . . . .. . . . . . . . . . . 3
Florin Balasa
2 Hierarchical Placement with Layout Constraints . . . . . . . . . . . . . . . . . . . . . . . . . . 61
Mark Po-Hung Lin and Yao-Wen Chang
3 Deterministic Analog Placement by Enhanced Shape Functions . . . . . . . . . . . . . . . 95
Martin Strasser, Michael Eick, Helmut Graeb,
and Ulf Schlichtmann
Part II Routing
4 Routing Analog Circuits . . . . . . .. . . . . . . . . . . . . . . . . . . . . . . . . . . . .149
G¨unhan D¨undar and Ahmet Unutulmaz
Part III Layout in the Design Flow
5 Analog Layout Retargeting . . . . . . . .  . . . . . . . . . . . . . . . . . . . . . . . . .205
Hazem Said, Mohamed Dessouky, Reem El-Adawi,
Hazem Abbas, and Hussein Shahein
6 Closing the Gap Between Electrical and Physical Design:
The Layout-Aware Solution. . . . . . . . .  . . . . . . . . . . . . . . . . . . . . . . . . .243
Rafael Castro-L´opez, Elisenda Roca, and Francisco V.
Fern´andez
7 Constraint-Driven Design Methodology:
A Path to Analog Design Automation.. .  . . . . . . . . . . . . . . . . . . . . . . . . . .269
G¨oran Jerke, Jens Lienig, and Jan B. Freuer
Index . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .299
发表于 2011-2-11 17:14:42 | 显示全部楼层
xiexie good
发表于 2013-3-19 20:37:19 | 显示全部楼层
下来看看
发表于 2015-8-15 12:10:23 | 显示全部楼层
回复 1# dainv
非常感谢
发表于 2015-10-19 23:10:27 | 显示全部楼层
了解一下
发表于 2015-10-20 08:30:23 | 显示全部楼层
good!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
发表于 2016-7-25 13:26:17 | 显示全部楼层
Thanks a lot for sharing
GMT+8, 2025-12-27 08:14 , Processed in 0.020796 second(s), 2 queries , Gzip On, Redis On.
