查看: 1981|回复: 0
[原创] 求助 : DM648中斷服務副程式(ISR)的配置??
发表于 2010-10-13 10:20:41 | 显示全部楼层 |阅读模式
hi 大家好
我是是剛使用TI DM648的新人,想請教各位前輩關於ISR配置的問題。
用DM648 EVM Board開發關於Video In/Out 的Project。
以Video Port 3 作為Input, 然後偵測Video Capture complete與EDMA3 Trasfer complete。
目前用Polling的方式偵測中斷的產生,但想用ISR取代之。
先說明Polling Reister中斷,且已經能成功偵測。
1. Polling CCMPA bit of VPIS for Video Capture complete.
2. Polling TTC bit of IPR/IPRH for EDMA3 Trasfer complete.
接著想以ISR取代之,但一直無法成功,請問是哪邊出了問題??
以下是我ISR的配置流程(pseudo code)。
1. 首先配置中斷向量表文件。(如下圖所示)
2. 接著中斷分配。
INTMUX2 |= 40; //VP3 interrupt assing to  int 8
3. 配置IVT Pointer(ISTP)至vectors。
ISTP = &(vectors);
4. Enable VP3
VPCaptEnable();
最後一直無法進入c_int08 ISR中.........
* Global symbols defined here and exported out of this file
   .global _vectors
   .global _c_int00
   .global _vector1
   .global _vector2
   .global _vector3
   .global _vector4
   .global _vector5
   .global _vector6
   .global _vector7
   .global _c_int08  ; Hookup the c_int08 ISR in main()
   .global _vector9
   .global _vector10
   .global _vector11
   .global _vector12
   .global _vector13
   .global _vector14
   .global _vector15
* Global symbols referenced in this file but defined somewhere else.
* Remember that your interrupt service routines need to be referenced here.
   .ref _c_int00
* This is a macro that instantiates one entry in the interrupt service table.
VEC_ENTRY .macro addr
    STW   B0,*--B15
    MVKL  addr,B0
    MVKH  addr,B0
    B     B0
    LDW   *B15++,B0
    NOP   2
    NOP
    NOP
   .endm
* This is a dummy interrupt service routine used to initialize the IST.
_vec_dummy:
  B    B3
  NOP  5
* This is the actual interrupt service table (IST). It is properly aligned and
* is located in the subsection .text:vecs. This means if you don't explicitly
* specify this section in your linker command file, it will default and link
* into the .text section. Remember to set the ISTP register to point to this
* table.
.sect ".text:vecs"
.align 1024
_vectors:
_vector0:   VEC_ENTRY _c_int00    ;RESET
_vector1:   VEC_ENTRY _vec_dummy  ;NMI
_vector2:   VEC_ENTRY _vec_dummy  ;RSVD
_vector3:   VEC_ENTRY _vec_dummy
_vector4:   VEC_ENTRY _vec_dummy
_vector5:   VEC_ENTRY _vec_dummy
_vector6:   VEC_ENTRY _vec_dummy
_vector7:   VEC_ENTRY _vec_dummy
_vector8:   VEC_ENTRY _c_int08    ; Hookup the c_int08 ISR in main()
_vector9:   VEC_ENTRY _vec_dummy
_vector10:  VEC_ENTRY _vec_dummy
_vector11:  VEC_ENTRY _vec_dummy
_vector12:  VEC_ENTRY _vec_dummy
_vector13:  VEC_ENTRY _vec_dummy
_vector14:  VEC_ENTRY _vec_dummy
_vector15:  VEC_ENTRY _vec_dummy
GMT+8, 2025-11-8 04:06 , Processed in 0.012551 second(s), 5 queries , Gzip On, Redis On.
