查看: 5300|回复: 0
怎么使用太阳能电池模拟软件AMPS-1D
发表于 2010-10-9 13:22:40 | 显示全部楼层 |阅读模式
AMPS-1D软件
AMPS stands for Analysis of Microelectronic and Photonic Structures. It was engineered to be a very general and versatile computer simulation tool for the analysis of device physics and for device design.
! h( {0 N/ A: D, b) g) t( vThe objective of AMPS is to teach how material properties (e.g., band gap, affinity, doping, mobilities, doping, gap state defect distributions in the bulk and at interfaces, etc) and device design/structure together control device physics and thereby device response to light, impressed voltage, and temperature. AMPS allows users to learn the "whys" of device response to a given situation (i.e., light bias, voltage bias, and temperature) through exploring and comparing band diagram, current component, recombination, generation, and electric field plots available from AMPS as a function of light intensity, voltage, temperature, and position.
GMT+8, 2025-12-21 15:00 , Processed in 0.017588 second(s), 5 queries , Gzip On, Redis On.
