楼主: xiaosha921
[求助] 求助:cadence 后仿真出现 An instance of an undefined model
发表于 2013-11-12 16:29:54 | 显示全部楼层
On the QRC Extraction form, go to the Netlisting tab, and ensure that you have Parasitic Capacitor Models and Parasitic Resistor Models set to either "Include As Comment" or "Do not include". You must have had it set to "Include Model".
That's useful if you want to provide a model to (say) scale the capacitance or resistance, but if you don't have such a model, you're best to leave them so that no model name is given. In this case, they'll get netlisted as resistor and capacitor in spectre.
发表于 2013-11-12 23:10:49 | 显示全部楼层
看看楼上的总结
发表于 2013-11-13 11:10:57 | 显示全部楼层
我用的一个工艺库,MOSFET可以仿真,里面的电阻就说找不到model,也很无语啊。lz解决了没有?
发表于 2013-11-15 10:50:48 | 显示全部楼层
如果用到了bjt section还要加biptypical,若有库里的电阻电容也要另外加
发表于 2014-7-1 13:39:41 | 显示全部楼层
谢谢楼主
发表于 2014-7-2 06:41:28 | 显示全部楼层
回复 1# xiaosha921
   在ADE的"model"里定义这个block
发表于 2014-11-30 16:45:58 | 显示全部楼层
感谢djlxfl
发表于 2015-3-24 15:20:28 | 显示全部楼层
同感,求解
发表于 2015-4-15 11:16:41 | 显示全部楼层
工艺库一般在哪儿有?
发表于 2015-9-24 16:03:54 | 显示全部楼层
回复 10# weirongcheng
   恩,就是这个错误啊,可是怎么添加啊?
GMT+8, 2025-9-21 08:36 , Processed in 0.018469 second(s), 3 queries , Gzip On, Redis On.
