查看: 4202|回复: 4
我求ISE新版本的ip source
发表于 2005-5-15 12:47:04 | 显示全部楼层 |阅读模式
哪位仁兄有ISE7.1或6.3或稍新一点的ISE版本内ip source,可否上传,先谢过了!
我想要verilog部分的xilinx core source,但是我只有6.1版本环境,ip太老了,我想参考新版的source部分!
再谢!
发表于 2006-12-5 23:00:23 | 显示全部楼层
我也正在寻!
发表于 2007-1-30 00:33:45 | 显示全部楼层
IP
你可以在xilinx公司网站上下载更新IP
发表于 2012-4-1 14:44:41 | 显示全部楼层
1.the format of encrypted file
> > > can_v1_5/can_tl_bsp.vhd as an example.
> > > a)the first 8 bytes XlxV38EB is version code
> > > b)the first 8bytes of line2 is the length of the ciphertext.,it means
> > > that the next segment of ciphertext is after 3230H
> > > c)from 18h bytes is ciphertext which is made by the Zlib compress then
> > > DES encrypted.
> > > 00000000h: 58 6C 78 56 33 38 45 42 20 20 20 20 66 61 30 30 ;
> > > XlxV38EB    fa00
> > > 00000010h: 20 20 20 20 33 32 33 30 39 1E 5F B2 14 42 33 C1 ;
> > > 32309._?B3?
> > > 00000020h: 82 40 EA 28 A0 8D 8C E9 8B 75 8B 0E 7C C4 6E BA ;
> > > ?@??????u?|?n?
> > > 00000030h: B0 2F 08 7C 51 C0 B0 45 01 D5 BD B8 73 A1 A1 09 ; ?.|Q腊E.战?s
> > > 00000040h: 71 2A 81 FA A7 9E 99 CA 9C BE 15 7C 44 D1 E9 C1 ; q*????????.|D
> > > 验?
> > > 00000050h: D5 A8 81 9B 1E 3A 19 47 4A 49 AA 87 1C E2 E2 46 ; 炸??.:.GJI??.
> > > 忖F
> > > 00003220h: 0F DD 81 68 7A B1 C5 92 FD 7C 77 FB 73 96 46 82 ; .??hz迸??|w?s
> > > ?F?
> > > 00003230h: A4 63 0B F1 64 17 1D D5 18 19 B2 E8 1D 23 DF 0F ; ?c.?d..?.
> > > 茶.#?
> > > 00003240h: 24 11 C2 D4 D0 90 38 7D 58 6C 78 56 33 38 45 42 ; $.略??8}
> > > XlxV38EB
> > > 00003250h: 20 20 20 20 36 38 64 37 20 20 20 20 31 34 66 63 ;
> > > 68d7    14fc
> > > 00003260h: D5 F9 A3 5C F9 7D D7 4A 72 09 19 86 03 62 C4 2C ; 争?\?}?Jr..?
> > > b?
> > > 00003270h: FE DC 28 58 7E 1F 91 2F 0F CD A8 DB 8E A0 FF 37 ; ??(X~.?.通???
> > > 7
> > > 00003280h: 01 F4 62 07 CE BA 6E 3C BB 67 4C B0 D9 E8 AE E3 ; .?b.魏n<?gL百
> > > 璁
> > > 2.how to decrypt
> > > 1)With DES, each 8bytes block is encrypted under same DES key。
> > > if the ciphertext can't be divided evenly,don't process these left
> > > bytes。
> > > 2)the DES key of Xilinx IPCOREis same 8f c2 d3 a0 XX XX  XX XX,which
> > > be recover by below couple dates。
> > > ciphertext 39 1E 5F B2 14 42 33 C1
> > > plaintext75 41 73 32 dd 59 ea 0c
> > > 3)XOR with the initial date 0d 9b 9e 4f b6 2a f1 37
> > > 4)then we  get 78 73 32 dd xx xx xx xx
> > > 5)replace the initial XOR date by this 8 bytes39 1E 5F B2 14 42 33 C1,
> > > 6)go to 2
> > > 7)combine to a file
> > > 3.download ZLIB fromhttp://www.zlib.net/
> > > 1)call the unpress function inf(file1,file2);
> > > 2)the we got the source code file2 as below:
> > > -- $Id: can_tl_bsp.vhd,v 1.1.2.2 2007/05/28 13:39:29 snori Exp $
> > > -- Copyright(C) 2007 by Xilinx, Inc. All rights reserved.
> > > -- This text/file contains proprietary, confidential
> > > -- information of Xilinx, Inc., is distributed under
> > > -- license from Xilinx, Inc., and may be used, copied
> > > -- and/or disclosed only pursuant to the terms of a valid
> > > -- license agreement with Xilinx, Inc. Xilinx hereby
> > > smcomb: process(state, RXE_COUNTER_I, SM_STUFFBIT_PD,SM_STUFFBIT,
> > >        BSOFF_COUNTER_I,  TEC_INC8_I, EMU_TEC_BOFF_LT1,
> > >        EMU_REC_ERRACT,BTL_RXBIT,IC_MSR_LBACK,IC_MSR_SLEEP,
> > >        TX_HPB_EMPTY,TX_FIFO_EMPTY)
> > >   begin
> > >     -- Enable Stuff Module when State = ID and after the 3rd bit
> > >     -- after SOF been received.
> > >     if (state = ID and RXE_COUNTER_I = C3) then
> > >       RXE_SM_EN <= '1';
> > >     else
> > >       RXE_SM_EN <= '0';
> > >     end if;
> > >     -- Reset CRC when State = EOF
> > >     -- When RXE_CRC_RST = '1', the CRC register is reset.
> > >     -- Reset when State = EOF and RXE_COUNTER_I = CO
> > >     -- (After ACK field)
> > >     -- Reset when in ERRACT and ERRPASS and RXE_COUNTER_I = C0. It is
> > > possible
> > >     -- that Reset could be asserted for multiple cycles.
> > >     if ((state = EOF and RXE_COUNTER_I = C0) or
> > >        ((state = ERRACT or state = ERRPASS) and RXE_COUNTER_I = C1)
> > >          or state = BOFF) then
> > >       RXE_CRC_RST <= '1';
> > >     else
> > >       RXE_CRC_RST <= '0';
> > >     end if;
> > this is COMMON knowledge for long time already
> > i wrote a zlib based encoder many many years ago for a study
> > but thank you for making it public-public!
> > Antti
> Hello Antti,
> can you point me to your encoder please ?
> Thanks!
> /HB
Hi HB, it's easy to make a decoder like below
//Initial XOR seeds
  xorseed={0x0d,0x9b,0x9e,0x4f,0xb6,0x2a,0xf1,0x37};
do
//read and process 8 bytes every time
        unRead = fread(crypt, SIZE, 8, encryptfile);
  //Call DES decrypt function
                DES(&crypt[i*SIZE],&decrypt[i*SIZE], 8, deskey, DECRYPT);
  // decrypted results XOR with the initial XOR seeds
                                                decrypt[i*SIZE]^=xorseed[0];
                                                decrypt[i*SIZE+1]^=xorseed[1];
                                                decrypt[i*SIZE+2]^=xorseed[2];
                                                decrypt[i*SIZE+3]^=xorseed[3];
                                                decrypt[i*SIZE+4]^=xorseed[4];
                                                decrypt[i*SIZE+5]^=xorseed[5];
                                                decrypt[i*SIZE+6]^=xorseed[6];
                                                decrypt[i*SIZE+7]^=xorseed[7];
  //Update the XOR seeds by last encrypted 8 bytes
                                                xorseed[0]=crypt[i*SIZE];
                                                xorseed[1]=crypt[i*SIZE+1];
                                                xorseed[2]=crypt[i*SIZE+2];
                                                xorseed[3]=crypt[i*SIZE+3];
                                                xorseed[4]=crypt[i*SIZE+4];
                                                xorseed[5]=crypt[i*SIZE+5];
                                                xorseed[6]=crypt[i*SIZE+6];
                                                xorseed[7]=crypt[i*SIZE+7];
        //write to a file or keep in memory
  fwrite(decrypt, SIZE, unRead, compressfile);
                                } (!feof(cryptfile) && unRead != 0);
//Call ZLIB uncompress
inf(compressfile,plaintextfile);
发表于 2012-4-1 14:45:16 | 显示全部楼层
> > > DES encrypted.
> > > XlxV38EB    fa00
> > > 32309._?B3?
> > > ?@??????u?|?n?
> > > 验?
> > > 忖F
> > > ?F?
> > > 茶.#?
> > > XlxV38EB
> > > 68d7    14fc
> > > b?
> > > 7
> > > 璁
> > > 2.how to decrypt
> > > bytes。
> > > 6)go to 2
> > > 7)combine to a file
> > >   begin
> > >       RXE_SM_EN <= '1';
> > >     else
> > >       RXE_SM_EN <= '0';
> > >     end if;
> > > possible
> > >       RXE_CRC_RST <= '1';
> > >     else
> > >       RXE_CRC_RST <= '0';
> > >     end if;
> > Antti
> Hello Antti,
> Thanks!
> /HB
//Initial XOR seeds
do
GMT+8, 2025-12-30 06:42 , Processed in 0.017770 second(s), 8 queries , Gzip On, Redis On.
