查看: 38920|回复: 95
Cadence SPB 16.3 for linux (FULL)-27links rapidshare
发表于 2010-9-17 15:06:53 | 显示全部楼层 |阅读模式
after download complete and uncompress ,you will get:
Base_SPB16.30.000_lnx86_1of5.tar
Base_SPB16.30.000_lnx86_2of5.tar
Base_SPB16.30.000_lnx86_3of5.tar
Base_SPB16.30.000_lnx86_4of5.tar
Base_SPB16.30.000_lnx86_5of5.tar
license.t.Z
LibCD.t.Z
install:
EXTRACT THE TAR FILES
tar xvf Base_SPB16.30.000_lnx86_1of5.tar
tar xvf Base_SPB16.30.000_lnx86_2of5.tar
tar xvf Base_SPB16.30.000_lnx86_3of5.tar
tar xvf Base_SPB16.30.000_lnx86_4of5.tar
tar xvf Base_SPB16.30.000_lnx86_5of5.tar
GOTO TO SPB16.30.000_lnx86.Base/CDROM1 DIRECTORY
tar -xzvf IScape03.71-p002lnx86.t.Z
cd iscape/bin
sudo ./iscape.sh
SELECT Install from a Local Directory/Media
IN THE SOURCE DIRECTORY SELECT WHERE YOU HAVE THE CDROM1 DIRECTORY
SELECT PRODUCT MANUALLY
IN INSTALL DIRECTORY SELECT /opt/cadence/spb163
MARK ALL PRODUCTS
RUN CONFIGURATION FOR ALL PRODUCT
CLOSE ISCAPE
EXTRACTTHE FILE license.t.Z (tar xvfz  license.t.Z) and copy license.dat in/opt/cadence/spb163/share/license and pubkey  in /opt/cadence/spb163
EDIT license.dat and change DAEMON cdslmd line for:
DAEMON cdslmd /opt/cadence/spb163/tools.lnx86/bin/64bit/cdslmd
EDIT .profile and add:
# Cadence SPB environment
#export MWLOOK=windows
export CDS_AUTO_64BIT=ALL
export CDS_INST_DIR=/opt/cadence/spb163
export CDS_LIC_FILE=$CDS_INST_DIR/share/license/license.dat
export CDS_DIR=$CDS_INST_DIR
export CONCEPT_INST_DIR=$CDS_DIR
export CDS_SITE=$CDS_DIR/share/local/
export LD_LIBRARY_PATH=$LD_LIBRARY_PATHCONCEPT_INST_DIR/tools/lib
export CDSDOC_PROJECT=/CDS_INST_DIR/doc
exportPATH=$PATHCDS_INST_DIR/tools/jre/binCONCEPT_INST_DIR/tools/bin:%$CONCEPT_INST_DIR/tools/libutil/bin:$CONCEPT_INST_DIR/tools/pcb/bin:$CONCEPT_INST_DIR/tools/fet/bin:$CONCEPT_INST_DIR/tools/PSpice:$CONCEPT_INST_DIR/tools/PSpice/Library:$CONCEPT_INST_DIR/tools/specctra/bin:$CONCEPT_INST_DIR/bin:$CONCEPT_INST_DIR/tools/Capture:$CONCEPT_INST_DIR/tools/specctra/bin:
EDIT .bashrc and add:
alias lmupli='/opt/cadence/spb163/tools/bin/64bit/lmgrd -c /opt/cadence/spb163/share/license/license.dat'
alias lmdownli='/opt/cadence/spb163/tools/bin/64bit/lmdown -c /opt/cadence/spb163/share/license/license.dat'
spb16.3 linux.zip
431 Bytes, 下载次数: 781 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-9-17 15:29:15 | 显示全部楼层
its picture
 楼主| 发表于 2010-9-18 09:13:14 | 显示全部楼层
it's full ,consists all feature
发表于 2010-9-18 12:18:34 | 显示全部楼层
thanks
发表于 2010-9-18 15:52:59 | 显示全部楼层
thanks a lot
发表于 2010-9-18 17:56:09 | 显示全部楼层
Thanks for sharing...
发表于 2010-9-18 18:11:59 | 显示全部楼层
download zhong , thanks ,
发表于 2010-10-8 21:19:28 | 显示全部楼层
谢谢楼主!
发表于 2010-10-12 02:19:26 | 显示全部楼层
could you upload the crack or license separately plz?
thanks
发表于 2010-10-12 13:38:38 | 显示全部楼层
感谢大侠.
GMT+8, 2025-12-30 01:06 , Processed in 0.029510 second(s), 8 queries , Gzip On, Redis On.
