查看: 2455|回复: 3
[招聘] 【猎头职位】Layout Design Engineer
发表于 2010-9-14 01:00:27 | 显示全部楼层 |阅读模式
LocationShanghai
-Work closely with circuit designer to implement high-performance custom mix-signal analog designs and develop mask layouts for consumer/medical/automotive application products.
-Join a cross-functional team responsible for developing leading edge IC products that ultimately achieve high volume production.
Job Qualifications
- Bachelor's degree in Electrical Engineering (or related field) or equivalent experience
- Minimum three years experience in custom analog IC physical design
- Experience with schematic-driven layout, floor planning, chip level routing, design for manufacturing and design rule and connectivity verification is required
- Experience using Cadence Virtuoso XL preferred
E-mail:cavell.zou@yaxunhr.com
- Familiarity with both analog and digital layout tools and flows, circuit design concepts and IC manufacturing processes desired
发表于 2010-9-14 17:59:55 | 显示全部楼层
dddddddddddddddddd
 楼主| 发表于 2011-3-16 15:02:38 | 显示全部楼层
谢谢支持,欢迎引荐朋友哦!
发表于 2011-4-16 01:45:15 | 显示全部楼层
路过。
GMT+8, 2025-12-20 07:29 , Processed in 0.021184 second(s), 6 queries , Gzip On, Redis On.
