查看: 36613|回复: 82
SMIC 0.18um 数字电路 standard单元库和IO单元库
发表于 2010-9-1 20:48:49 | 显示全部楼层 |阅读模式
提供一份比较完整的数字电路开发库,包括Standard单元库和IO单元库。
目录如下:
IO:
    Floorplan:    用于布局用的blackbox形式verilog描述
    LEF:        SOC Encounter布局布线用苦
    Symbol:
        Cadence:    Cadence符号图
        edif:        Edif符号图
        synopsys:    Synopsys符号图
    Synopsys:    Synopsys用的综合库
    TLF:        时序延迟文件
    Verilog:    仿真用Verilog描述
STD:
    Fastscan:    用于Mentor的DFT工具Fastscan使用的ATPG库
    Symbol:
        Cadence:    Cadence符号图
        edif:        Edif符号图
    TLF:        时序延迟文件
其中ApplicationNotes_DesignKit.txt文件如下:
         VeriSilicon SMIC 0.18um High-Density Standared Cell Library Application Notes
1.Recommend Operating Conditions
                                      typ     max      min
  core DC supply voltage(volt)        1.8v    1.98v    1.62v
  IO   DC supply voltage(volt)        3.3v    3.6v     3.0v
  Junction temperature(centigrade)    25      125      0
2.Derating Factors
  The derating factors of VeriSilicon SMIC 0.18um High-Density Standared Cell Library given
  in document SMIC18STDLib.pdf are for pre-layout estimation only.
3.Synopsys Model
  a.The wire load models given in our synopsys library are for your REFERENCE ONLY. So please
    create a customized wire load model appropriate for your design.
  b.Please consider for which cell, if any, should be added dont_use and dont_touch during
    synthesis and ignore our settings.
  c.Since our synthesis tools' version may be different from yours, it is recommended that you
    create the db file using your own library compiler tools.
  d.When reading in the model, synopsys tools will give some warning which should be ignored. The following is the warning list to be ignored:
Warning: Line xxx, The 'values' attribute has a '-x.xxxxxx' value,
        which is less than '0.000000' the minimum recommended value of this attribute. (LBDB-272)
Warning: Line xxx, The 'SN' pin of the 'XXXX' design is not a clock pin
and should not be used in the 'related_pin' of 'setup' timing arc. (LIBG-104)
Warning: Line xx, The 'Z' Pin/bus on the 'HOLDHD' cell has no 'function' a
ttribute.
        The cell becomes a black box. (LIBG-16)
Information: Line 197792, No internal_power information for the 'TIEHHD' cell. (LBDB-301)
Information: Line 197792, No internal_power information for the 'TIELHD' cell. (LBDB-301)
Warning: Line xx, The 'default_leakage_power_density' attribute is not spe
cified. Using 0.00. (LBDB-172)
Warning: Line 4, The units of time, capacitance, voltage and current are not consistent.(LBDB-602)
4.Ambit Sdf Writing
  When using Ambit to write 2.1 version sdf, please use this option
  "-edges edged". The following is the eample:
  ac_shell> write_sdf -version 2.1 -interconn all -edges edged -splitsethold design.sdf
5.SDF file
  If you generate version 2.1 sdf file using synopsys design compiler(Version 2002.08 or
  later) or Ambit, please use the script Modify_SDF_2_1.pl to modify
  the sdf file before doing back-annotation using Verilog-XL.
  file : Synopsys/Modify_SDF_2_1.pl
  cmd line : Modify_SDF_2_1.pl sdf_file
  result : sdf_file - can be used for back-annotation
           sdf_file.bak - back-up file
6.Formality comment
  If your design can not pass Synopsys Formality tool, commenting the cell HOLDHD from your design   may help you.
7. Cell list comment
  There are 499 basic cells in the library and add 9 FILLERC*HD cells in fastscan model.
8. SDF back-annotation simulation
  When doing sdf back-annotation in VCS(V6.2 and above), the option "+overlap" is necessary and the following
warning may appears.
  Warning : The sum of a negative timing check limits should be greater than or equal to 0. Setting negative
limits to 0. ("<verilog_model_filename>", xxxx).
 楼主| 发表于 2010-9-1 21:07:23 | 显示全部楼层
附件如下:
smic18_digital_lib.part01.rar
4.76 MB, 下载次数: 890 , 下载积分: 资产 -3 信元, 下载支出 3 信元
smic18_digital_lib.part02.rar
4.76 MB, 下载次数: 778 , 下载积分: 资产 -3 信元, 下载支出 3 信元
smic18_digital_lib.part03.rar
4.76 MB, 下载次数: 726 , 下载积分: 资产 -3 信元, 下载支出 3 信元
smic18_digital_lib.part04.rar
4.76 MB, 下载次数: 694 , 下载积分: 资产 -3 信元, 下载支出 3 信元
smic18_digital_lib.part05.rar
4.76 MB, 下载次数: 753 , 下载积分: 资产 -3 信元, 下载支出 3 信元
smic18_digital_lib.part06.rar
4.76 MB, 下载次数: 682 , 下载积分: 资产 -3 信元, 下载支出 3 信元
smic18_digital_lib.part07.rar
2.32 MB, 下载次数: 667 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-9-2 01:39:39 | 显示全部楼层
发表于 2010-9-2 01:42:54 | 显示全部楼层
发表于 2010-9-2 02:39:46 | 显示全部楼层
发表于 2010-9-2 03:20:08 | 显示全部楼层
发表于 2010-9-2 08:36:44 | 显示全部楼层
谢谢楼主。
发表于 2010-9-2 08:42:36 | 显示全部楼层
应该是设计用的。
发表于 2010-9-2 09:19:22 | 显示全部楼层
不错啊!收集一个。
发表于 2010-9-2 17:01:30 | 显示全部楼层
是arm的还是verisilicon的?
GMT+8, 2025-12-24 19:12 , Processed in 0.024533 second(s), 4 queries , Gzip On, Redis On.
