查看: 3073|回复: 1
calibre 2008.1 安装问题求教
发表于 2010-8-25 10:29:26 | 显示全部楼层 |阅读模式
安装之后启动日志mg.log里面显示如下信息:
。。。。。。。上面若干略去
10:18:06 (mgcld) znmnhtb  znmniblink znmnlpc
10:18:06 (mgcld) znmnpci  znmnpcix znmnpcix20
10:18:06 (mgcld) znmnposphyl2 znmnposphyl3 znmnposphyl4
10:18:06 (mgcld) znmnqdrsram znmnrapidio znmnsdram
10:18:06 (mgcld) znmnsigmaram znmnspi42 znmnusb11
10:18:06 (mgcld) znmnutopial1 znmnutopial2 znmnutopial3
10:18:06 (mgcld) znmnutopial4 znmonitorsim znsimmrt
10:18:06 (mgcld) znurf1  znurfl  znvhdl
10:18:06 (mgcld)
10:18:06 (mgcld) Licenses are case sensitive for mgcld
10:18:06 (mgcld)
10:18:06 (mgcld) EXTERNAL FILTERS are OFF
10:18:06 (lmgrd) mgcld using TCP-port 32832
终端显示是:// Warning: Encountered licensing problem:
//  A FATAL CS ERROR for calinteractive feature detected
// Error: Calibre exiting due to licensing problems acquiring CALIBREINTERACTIVE
不知道有遇到过这种问题的没......
求解决......
 楼主| 发表于 2010-8-25 10:38:36 | 显示全部楼层
求助求助~~~~~~
GMT+8, 2025-12-20 12:24 , Processed in 0.015662 second(s), 7 queries , Gzip On, Redis On.
