查看: 2365|回复: 2
DC 2008安装问题 The feature is needed
发表于 2010-8-24 13:44:47 | 显示全部楼层 |阅读模式
我前不久刚刚弄了下DC,没有安装成功,有其他事就耽搁了。昨天开始正式安装和学习DC,可是总是遇到这个问题,我看了论坛中也有不少人遇到这个问题,好多人都解决了,但是就是没有谁说具体是怎么解决的,特此询问各位前辈高手们,这个问题如何解决。
    我在redhat AS4,AS4,Ubuntu10.04都试过了,全都出现这个问题。郁闷中啊!急救。安装遇到了不少问题,成功后,我自己写一个小结共享给所有后手....
Checking the integrity of the license file....
13:44:15 (snpslmd) Valid SSS feature found.
13:44:15 (snpslmd) The feature is needed to enable the other keys in your license file.
13:44:15 (snpslmd) -------------------------------------
在此先谢过!
 楼主| 发表于 2010-8-24 13:46:05 | 显示全部楼层
13:44:14 (snpslmd) ALTGEN1                ALTGEN2                amat-calib_all
13:44:14 (snpslmd) amga                amps                amps/cso
13:44:14 (snpslmd) amps/pfx        amps/tr                AN-Impl3D_all
13:44:14 (snpslmd) any_technology
13:44:14 (snpslmd)
13:44:14 (snpslmd) Licenses are case sensitive for TE_CATS
13:44:14 (snpslmd)
13:44:14 (snpslmd) EXTERNAL FILTERS are OFF
13:44:14 (lmgrd) snpslmd using TCP-port 37995
13:44:14 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  archprod  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  sandwork  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snpsOEM5  snpsOEM6  snpsOEM7  snpsOEM8  snpsOEM9  ssilmd  synopsysd  tmald  vcsd
13:44:15 (snpslmd) ------------------------------------------------------------------
13:44:15 (snpslmd) Checking the integrity of the license file....
发表于 2015-2-12 17:32:50 | 显示全部楼层
同问!
GMT+8, 2025-12-22 07:07 , Processed in 0.012501 second(s), 3 queries , Gzip On, Redis On.
