楼主: joker48
cadence encounter test 91 license problem
发表于 2012-3-1 16:44:47 | 显示全部楼层
[clx@ktic ~]$ et
Encounter(R) Test and Diagnostics 9.1.100 Dec 07, 2009 (linux26 ET911)
Starting /usr/eda/cadence/et9.1/tools.lnx86/tb/tcl/main/guiMainForm.tcl
ERROR (TDA-011): Failed to obtain a license to run Encounter Test Graphical User Interface.
    Tried to get license(s): Test_Design_Analysis
    Check license server information to determine what you need to do to
    obtain a required license and rerun.  [end TDA_011]
发表于 2012-3-15 11:02:53 | 显示全部楼层
同样的问题。单独用ckout_test是可以check out出Test_Design_Analysis的。应该是ET软件没完全破解,期待高手。
发表于 2012-3-16 00:33:01 | 显示全部楼层
Wrong!. Incomplete!
发表于 2012-6-22 00:33:48 | 显示全部楼层
请求高手破解
发表于 2012-6-24 12:05:19 | 显示全部楼层
看看,呵呵~~
发表于 2013-7-3 14:54:07 | 显示全部楼层
I get the same exact error messages  with the versions ET 11 and ET 12 . None of the known SFK patches are working for the Cadence test package (both 32 and 64 bit versions). I believe nobody has been able to crack it so far ?
发表于 2013-10-24 14:23:57 | 显示全部楼层
这个有没有人起来的,说一声
发表于 2013-12-20 22:45:37 | 显示全部楼层
还没有K?
发表于 2014-1-3 21:47:04 | 显示全部楼层
need EDI 13 license
发表于 2015-2-17 23:13:37 | 显示全部楼层
Reply 37 # pat06
any success in the ET license. I have the same problem. No SFK patch work. Any success on ET license. I have the same problem. No SFK patch work.
GMT+8, 2025-12-30 17:00 , Processed in 0.020646 second(s), 4 queries , Gzip On, Redis On.
