美资公司 LSI 上海研发中心高薪诚聘存储通讯领域人才,薪水待遇优厚,部分人员有出国培训机会。(部门内部推荐,成功机会更高)
有意者请将中英文简历发送至:asic_tapeout@hotmail.com
Analog Custom Layout Engineer
DESCRIPTION OF DUTIES IN ADDITION TO THOSE IN JOB DESCRIPTION:
LSI's Storage Peripherals Group is looking for an experienced IC physical design engineer to
join the pre-amplifier design team. As a preamp physical design (layout) engineer you will work
closely with circuit design to implement high-speed custom analog designs and develop mask
layouts for customer products. You will join a cross-functional team responsible for developing
leading edge high-speed magneto electronic read/write IC products that ultimately achieve
high volume production.
- Layout high speed analog and mixed-signal custom chips for the hard disk drive industry
- Work directly with a team of engineers to determine floor plan, routing and I/O
requirements for preamp IC's
- Perform IC design rule and connectivity verification and drive products through mask
release flows.
- Contribute to methodology improvements to increase layout and verification efficiency.
PREFERRED EXPERIENCE:
- Bachelor's degree in Electrical Engineering (or related field) or equivalent experience
- Minimum three to five years experience in custom analog IC physical design
- Experience with schematic-driven layout, floor planning, chip level routing, design for
manufacturing and design rule and connectivity verification is required
- Experience using Cadence Virtuoso XL and VCAR router preferred
- Familiarity with both analog and digital layout tools and flows, circuit design concepts and
IC manufacturing processes desired |
