查看: 12728|回复: 23
[求助] 关于Questasim + OVM
发表于 2010-8-12 11:28:35 | 显示全部楼层 |阅读模式
请问各位大侠,做验证的时候一般都用什么版本的Questasim 和什么版本的OVM,我用Questasim6.4 + OVM 2.0.1行吗?但是用这个去运行网站:
http://www.testbench.in/CM_11_PHASE_8_SCOREBOARD.html给的例子,会报错:
# QuestaSim qverilog 6.4 Compiler 2008.06 Jun 18 2008
# -- Compiling package ovm_pkg
# -- Compiling module switch
# -- Compiling interface mem_interface
# -- Compiling interface input_interface
# -- Compiling interface output_interface
# ** Error: Sequencer.sv(13): Illegal parameter specification for non-parameterized class type.
# ** Error: Sequencer.sv(13): near "#": syntax error, unexpected '#', expecting ';'
# ** Error: Sequencer.sv(13): Error in class extension specification.
# ** Error: Sequencer.sv(20): super.new() call illegal for class with no super-class.
# ** Error: Sequence.sv(11): Illegal parameter specification for non-parameterized class type.
# ** Error: Sequence.sv(11): near "#": syntax error, unexpected '#', expecting ';'
# ** Error: Sequence.sv(11): Error in class extension specification.
# ** Error: Sequence.sv(14): super.new() call illegal for class with no super-class.
# ** Error: Sequence.sv(30): Illegal parameter specification for non-parameterized class type.
# ** Error: Sequence.sv(30): near "#": syntax error, unexpected '#', expecting ';'
# ** Error: Sequence.sv(30): Error in class extension specification.
# ** Error: Sequence.sv(33): super.new() call illegal for class with no super-class.
# ** Error: Driver.sv(13): Illegal parameter specification for non-parameterized class type.
# ** Error: Driver.sv(13): near "#": syntax error, unexpected '#', expecting ';'
# ** Error: Driver.sv(13): Error in class extension specification.
# ** Error: Driver.sv(25): super.new() call illegal for class with no super-class.
# ** Error: Environment.sv(32):  Failed to find name 'type_id' in specified scope
# ** Error: Environment.sv(33):  Failed to find name 'type_id' in specified scope
# ** Error: Environment.sv(36):  Failed to find name 'type_id' in specified scope
# ** Error: Environment.sv(40):  Failed to find name 'type_id' in specified scope
# C:/questasim_6.4/win32/qverilog failed.
我输入的编译命令是:
qverilog +incdir+ovm ovm/ovm_pkg.sv +incdir+. rtl.sv interface.sv top.sv -R +OVM_TESTNAME=test1
也是按照它给的例子的命令写的,其中我的库叫OVM,在所在工程的根目录下,已经编译了ovm_pkg。
其中,error对应的代码为:
class Sequencer extends ovm_sequencer #(Packet);
super.new(name, parent);
class Seq_device0_and_device1 extends ovm_sequence #(Packet);
super.new(name);
Drvr   = Driver::type_id::create("Drvr",this);
Seqncr = Sequencer::type_id::create("Seqncr",this);
Rcvr   = Receiver::type_id::create($psprintf("Rcvr%0d",i),this);
Sbd   = Scoreboard::type_id::create("Sbd",this);
  我看过OVM2.0.1的用户手册,那里面说的关于上面报错的语法都能上面语法中那么使用,但是不知道在这里为什么会报错,也就是说利用OVM2.0.1可以这么写:“class Sequencer extends ovm_sequencer #(Packet);”,但是在我这里就会出错,不知道为什么啊?是不是我的操作有问题?很多例子都是这样,在我这都不能运行了,老报错,这个问题困扰我好长时间了。
附件中的程序就是Phase8的程序代码。
各位能不能下载下来运行一下,帮我解答一下我的疑问,谢谢!
ovm_switch_8.tar
60 KB, 下载次数: 7 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-8-12 12:52:09 | 显示全部楼层
看下$OVM_HOME/README-Questa.txt就知道什么工具能支持什么版本的ovm了。看你的error,应该是include整个代码结构时出现了问题。
发表于 2010-8-12 12:59:19 | 显示全部楼层
嗯,同意楼上的意见,最好看看你的top里面'include的顺序。
 楼主| 发表于 2010-8-12 13:02:35 | 显示全部楼层
README-Questa.txt里面说的是QuestaSim支持OVM2.0.1啊?
2# whxqq
 楼主| 发表于 2010-8-12 13:28:57 | 显示全部楼层
有OVM2.0.1的库吗?是不是我的库有问题啊?
我是在EETOP上下的啊,不知道为什么,这个问题困扰我好长时间了,都不知道怎么解决。
3# gaurson
 楼主| 发表于 2010-8-12 13:48:24 | 显示全部楼层
照说我运行的这个是人家网站给的例子啊,不应该有错误,人家在网页上还给了运行结果呢,不知道为什么到我这就出现问题了,各位大侠帮帮忙吧。不是很大的例子,对于各位高手来说,运行一遍就能知道其中的问题了,谢谢各位了。
 楼主| 发表于 2010-8-12 15:45:59 | 显示全部楼层
顶一下,期待各位的答复
 楼主| 发表于 2010-8-13 13:08:30 | 显示全部楼层
没人理我啊!!!!
7# nangua001
发表于 2011-6-21 14:16:28 | 显示全部楼层
Questasim 6.5b verification for SyetemVerilog & Systemc 2.2.0 is wonderful,  OVM takes the place of AVM and becoming a main lib.
发表于 2011-6-22 09:35:40 | 显示全部楼层
來看看~~
GMT+8, 2025-12-5 19:53 , Processed in 0.025206 second(s), 8 queries , Gzip On, Redis On.
