楼主: RainskyXiang
[求助] 安装DC遇到lmgrd: command not found
发表于 2013-7-26 10:37:58 | 显示全部楼层
回复 1# RainskyXiang
   请问版大解决了吗?
发表于 2014-5-1 11:09:18 | 显示全部楼层
export PATH="*/eda/synopsys/scl/scl_v10.9.3/linux/bin:"$PATH
添加到.bashrc中     "*"你安装scl的前部分路径
发表于 2014-5-24 19:58:01 | 显示全部楼层
回复 12# ligang1986718
   我也遇到楼主同样的问题,PATH我也加了,但是就是有这样的提示:scl_v11.6/linux/bin/lmgrd: 没有那个文件或目录
希望指点一下,我用的是ubuntu11.04, scl11.06/11.04
发表于 2014-5-25 14:22:21 | 显示全部楼层
回复 13# mingrenyc
   估计目录没加对吧,细心点了
发表于 2014-6-14 23:07:34 | 显示全部楼层
我也遇到这个问题,是这样解决的。
The license manager daemon executable lmgrd and the vendor daemon BIOSOLVE in the FlexLM package for linux from http://www.biosolveit.de/download?product=bsit_flexlm rely on the following ld-libraries in your operating system:
/lib/ld-lsb.so.3 for the 32 bit lmgrd executable
/lib64/ld-lsb-x86-64.so.3 for the 64 bit lmgrd executable
If the respective file corresponding to your operating system and lmgrd executable (32 bit or 64 bit) does not exist, please ask your system administrator to install this file.
If you are the system administrator: The 64 bit version relies on the linux-standard-base (lsb) version of that ld shared object (.so).  Most probably you will have an ld library with a different name installed on your system, e.g. /lib64/ld-2.3.4.so.  Here, a symbolic link to that library will do the work, e.g.
% ll /lib64/ld-l*
lrwxrwxrwx  1 root root 11 2009-12-18 18:01 /lib64/ld-lsb-x86-64.so.3 -> ld-2.3.4.so*
The same for 32 bit:
% ll /lib/ld-l*
lrwxrwxrwx  1 root root 11 2009-12-18 18:01 /lib/ld-lsb.so.3 -> ld-linux.so.2*
After having created such a symbolic link, you should run ldconfig to update the linker cache.
发表于 2014-6-14 23:09:02 | 显示全部楼层
我也遇到类似问题,我是这么解决。
% ll /lib64/ld-l*
% ll /lib/ld-l*
发表于 2014-9-3 21:50:01 | 显示全部楼层
有没有高手指点一下,我在12.04下安装成功,在14.4下总提示不认识lmgrd,在所在目录执行也不认识(包括sudo)。
发表于 2014-9-19 23:38:07 | 显示全部楼层
回复 16# bigqubian
    thanks to bigqubian, it works after set link
发表于 2014-9-19 23:52:20 | 显示全部楼层
resolved, thanks!
发表于 2014-9-19 23:52:39 | 显示全部楼层
it is resolved, thanks!
GMT+8, 2025-12-23 17:51 , Processed in 0.017221 second(s), 3 queries , Gzip On, Redis On.
