查看: 2496|回复: 4
急需senior/staff dft engineer
发表于 2010-7-29 09:36:40 | 显示全部楼层 |阅读模式
Hi,需要senior/staff dft engineer,在上海,薪水面议,有兴趣的朋友可以联系susan.1817@hotmail.com
Staff DTF Engineer
Job Purpose:
Take the lead role developing DFT architecture, design and implementation from concept to mass production for low-power complex SoC chips targeting on single-digit DPPM.
Key Responsibilities:
  • Develop high-coverage DFT scheme, DFT methodology and manufacturing test flow.
  • Implement, verify and validate DFT logic.
  • Generate, verify and validate ATPG patterns for stuck-at, delay, bridging and iddq faults.
  • Write test vectors for ATE, verify, and convert them into tester format.
  • Participate in testing and debugging silicon.
  • Generate and maintain relevant design and user documentation.
  • Implement module in RTL using Verilog and assertions.
  • Review, document and improve existing module designs as needed.
  • Synthesize and optimize RTL code for testability, timing, area and power.
  • Assist in developing floor plans and performing full chip integration including 3rd party IPs and memory modules.
  • Work with physical design teams for optimizing layout and achieving timing closure on ASIC designs.
 楼主| 发表于 2010-7-30 09:57:29 | 显示全部楼层
up up
 楼主| 发表于 2010-8-2 09:36:44 | 显示全部楼层
up and up
 楼主| 发表于 2010-8-3 08:55:32 | 显示全部楼层
up it
 楼主| 发表于 2010-8-5 09:04:27 | 显示全部楼层
up and up
GMT+8, 2025-12-14 13:42 , Processed in 0.020489 second(s), 7 queries , Gzip On, Redis On.
