查看: 7198|回复: 23
[Paper]A High-Speed CMOS Current Opamp for Very Low Supply Voltage Operation
发表于 2006-9-19 15:40:11 | 显示全部楼层 |阅读模式
ABSTRACT
A CMOS implementation of a high-gain current mode operational amplifier (opamp) with a single-ended input and a differential output is described. This configuration is the current mode counterpart of the traditional voltage mode opamp. In order to exploit the inherent potential for high speed, low voltage operation normally associated with current mode analog signal processing, the opamp has been designed to operate off a supply voltage of 1.5V, and the signal path has been confined to N-channel transistors. With this design, a gain of 94dB and a gain-bandwidth product of 65MHz has been achieved at a power consumption of 30pW.
A High-Speed CMOS Current Opamp for Very Low Supply Voltage Operation.pdf
356.51 KB, 下载次数: 243 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-9-19 21:59:04 | 显示全部楼层
Thanks!!
 楼主| 发表于 2006-9-21 11:57:25 | 显示全部楼层
为什么IEEE上的paper没有人来下呢,很纳闷啊!
发表于 2006-12-2 13:28:20 | 显示全部楼层
Thanks!!
发表于 2006-12-2 21:36:50 | 显示全部楼层
xiexie,楼主了
发表于 2006-12-3 12:51:02 | 显示全部楼层
好东西一定要顶
发表于 2007-12-20 00:13:52 | 显示全部楼层
hoahoahohahoa
发表于 2008-4-30 16:18:26 | 显示全部楼层
haohaohaoh
发表于 2008-6-7 15:14:08 | 显示全部楼层
dingyige
头像被屏蔽
发表于 2008-9-10 15:00:33 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-12-30 02:27 , Processed in 0.025020 second(s), 6 queries , Gzip On, Redis On.
