查看: 3754|回复: 8
[Paper]A 24-GHz, +14.5-dBm Fully Integrated Power Amplifier in 0.18um CMOS
发表于 2006-9-19 15:19:49 | 显示全部楼层 |阅读模式
Abstract—A 24-GHz +14.5-dBm fully integrated power amplifier with on-chip 50ohm input and output matching is demonstrated in 0.18um CMOS. The use of substrate-shielded coplanar waveguide structures for matching networks results in low passive loss and small die size. Simple circuit techniques based on stability criteria derived result in an unconditionally stable amplifier. The power amplifier achieves a power gain of 7 dB and a maximum single-ended output power of +14.5-dBm with a 3-dB bandwidth of 3.1 GHz, while drawing 100 mA from a 2.8-V supply. The chip area is 1.26 mm2.
Index Terms—Amplifier stability, CMOS integrated circuits, coplanar waveguides, phased arrays, radio transmitters, silicon.
[ 本帖最后由 gmc832002 于 2006-9-19 15:33 编辑 ]
A 24-GHz, +14.5-dBm fully integrated power amplifier in 0.18-_spl mu_m CMOS.pdf
1.25 MB, 下载次数: 136 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-9-19 21:59:50 | 显示全部楼层
Thanks!!
 楼主| 发表于 2006-9-21 11:56:38 | 显示全部楼层
为什么IEEE上的paper没有人来下呢,很纳闷啊!
头像被屏蔽
发表于 2008-3-14 10:17:31 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
头像被屏蔽
发表于 2008-11-3 10:56:42 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2012-5-7 01:01:55 | 显示全部楼层
DDDDDDDDDDDDD
发表于 2015-3-9 18:42:04 | 显示全部楼层
kan kan,,,,,,,,,,,,,,,,,,
发表于 2018-9-10 22:42:33 | 显示全部楼层
谢谢楼主分享~ very good !!!
发表于 2019-7-30 11:54:49 | 显示全部楼层
thank you somuch
GMT+8, 2025-12-29 09:03 , Processed in 0.025080 second(s), 6 queries , Gzip On, Redis On.
