查看: 2309|回复: 0
7219驱动
发表于 2006-9-19 15:15:53 | 显示全部楼层 |阅读模式
NAME     DISP
?PR?CLR_DISP?DISP    SEGMENT CODE
?PR?CSH_DISP?DISP    SEGMENT CODE
?PR?DISP_IN1?DISP    SEGMENT CODE
?PR?DISP_IN2?DISP       SEGMENT CODE
PUBLIC CLR_DISP,CSH_DISP,_DISP_IN1,_DISP_IN2
    PCLK    bit    P1.7
    PLD    bit    P1.5
    PIN    bit    P1.6
;       函数名:    CLR_DISP
;       功  能:    CLEAR DISPLAY
RSEG ?PR?CLR_DISP?DISP
CLR_DISP:    MOV    R7,#8                ;8 digits
CLR_DISP0:    MOV    R5,#0FH                ;blank
        LCALL    _disp_in1            ;主max7219
        DJNZ    R7,CLR_DISP0
        MOV    R7,#8                ;8
digits
CLR_DISP1:    MOV    R5,#0FH                ;blank
        LCALL    _disp_in2            ;从max7219
        DJNZ    R7,CLR_DISP1
        RET
;    函数名:    CSH_DISP
;    功  能:    初始化7219各个寄存器
RSEG ?PR?CSH_DISP?DISP
CSH_DISP:    CLR    PLD
        MOV    R1,#50        ;delay 100us
        DJNZ    R1,$
        SETB    PLD
        MOV    R1,#50
        DJNZ    R1,$
;初始化主max7219各个寄存器
        MOV    R7,#0CH        ;Shutdown
        MOV    R5,#1        ;Normal Operation 1
        LCALL    _disp_in1
        MOV    R7,#0FH        ;Display Test
        MOV    R5,#01H        ;1: display 8.
        LCALL   _disp_in1
        MOV    R1,#50
        DJNZ    R1,$
        MOV    R7,#09H        ;Decode-Mode
        MOV    R5,#0FFH    ;8 digits Code B Font
        LCALL   _disp_in1
        MOV    R7,#0AH        ;REGISTER:Intensity
        MOV    R5,#9        ;FormatUTY CYCLE 19/32
        LCALL    _disp_in1
        MOV    R7,#0BH        ;REGISTER:Scan Limit
        MOV    R5,#07H        ;Formatisplay didits 0-7
        LCALL    _disp_in1
        MOV    R5,#00H        ;0: Normal Operation
        LCALL   _disp_in1
        CLR     PLD
        MOV    R1,#50
        DJNZ    R1,$
        SETB    PLD
        MOV    R1,#50
        DJNZ    R1,$
;初始化从max7219各个寄存器
;命令字和格式同上
        MOV    R7,#0CH
        MOV    R5,#01H
        LCALL   _disp_in2
        MOV    R7,#0FH
        MOV    R5,#01H
        LCALL   _disp_in2
        MOV    R1,#50
        DJNZ    R1,$
        MOV    R7,#09H
        MOV    R5,#0FFH
        LCALL   _disp_in2
        MOV    R7,#0AH
        MOV    R5,#9
        LCALL   _disp_in2
        MOV    R7,#0BH
        MOV    R5,#07H
        LCALL   _disp_in2
        MOV    R7,#0FH
        MOV    R5,#00H
        LCALL   _disp_in2
        RET
;    函数名:    _disp_in1
;    功  能:    将16位数据送入主max7219寄存器
;    输  入: R7 寄存器,地址
;               R5 寄存器,数据
RSEG ?PR?disp_in1?DISP
_disp_in1:      CLR     PLD             ;LOAD=0
        MOV    R6,#16
        MOV    A,#0
DIN_LP0:    CLR    PCLK
        RLC    A        ;带进位C的循环
        MOV    PIN,C
        SETB    PCLK
        DJNZ    R6,DIN_LP0
;通过16个CLK,将16个0通过DOUT送入从max7219的DIN
;也可以不需要这16个循环,只是为了同从max7219的程序区别起见
        MOV    R6,#8
        MOV    A,R7        ;将第一个字节的8位送入
DIN_LP1:    CLR    PCLK        ;寄存器,地址
        RLC    A
        MOV    PIN,C
        SETB    PCLK
        DJNZ    R6,DIN_LP1
        MOV    R6,#8
        MOV    A,R5        ;将第二个字节的8位送入
DIN_LP2:    CLR    PCLK        ;寄存器,数据
        RLC    A
        MOV    PIN,C
        SETB    PCLK
        DJNZ    R6,DIN_LP2
                SETB    PLD             ;LOAD 上升沿
        RET
;    函数名:    _disp_in2
;    功  能:    将16位数据送入从max7219寄存器
;    输  入: R7 寄存器,地址
;               R5 寄存器,数据
RSEG ?PR?disp_in2?DISP
_DISP_IN2:    CLR     PLD
        MOV     R6,#08H
        MOV     A,R7        ;R7 第一个字节8位
DIN_LP3:        CLR     PCLK
        RLC     A
        MOV     PIN,C
        SETB    PCLK
        DJNZ    R6,DIN_LP3
        MOV     R6,#08H
        MOV     A,R5        ;R5 第二个字节8位
DIN_LP4:        CLR     PCLK
        RLC     A
        MOV     PIN,C
        SETB    PCLK
        DJNZ    R6,DIN_LP4
        MOV    R6,#16
                MOV     A,#0
DIN_LP5:        CLR     PCLK
        RLC     A
        MOV     PIN,C
        SETB    PCLK
        DJNZ    R6,DIN_LP5
;通过16个clk,将R7,R5的16位数据通过DOUT送入从max7219的DIN
        SETB     PLD        ;LOAD 上升沿
        RET
                     END
测试程序:
#include <string.h>
#include <max7219.h>
#include <delay.h>
#define uchar unsigned char
#define uint  unsigned int
#define ulong unsigned long
uchar led_buf[17];
extern void led_printf();
extern void show_int(bit mode,ulong n);
void main()
    csh_disp();
    clr_disp();
    memset(led_buf,15,16);            // 初始化缓冲区
的内容,不显示
    while(1)
        show_int(0,12345678);        // 主max7219显示12345678
        show_int(1,98765432);        // 从max7219显示98765432
        delay_10ms(100);
        clr_disp();
        delay_10ms(100);
void led_printf()
    uchar i;
    for(i=0;i<8;i++)
        disp_in1(i+1,led_buf);
        disp_in2(i+1,led_buf[8+i]);
    ulong temp;
    uchar i=0;
    temp=n;
    if(!mode)
        for(i=0;i<7;i++)
            led_buf=15;
        led_buf[7]=0;
        i=0;
        while(temp>0)
            led_buf[7-i]=temp%10;
            temp/=10;
            i++;
    else
        for(i=0;i<7;i++)
            led_buf[8+i]=15;
        led_buf[15]=0;
        i=0;
        while(temp>0)
            led_buf[15-i]=temp%10;
            temp/=10;
            i++;
    led_printf();
GMT+8, 2025-12-28 15:38 , Processed in 0.013087 second(s), 6 queries , Gzip On, Redis On.
