Because of the difference between the aspect ratios of diffused resistors of practical value versus those of capacitors, the attainable matching accuracy is higher for capacitors given the same overall die area.
This results from the fact that no net charge redistribution between capacitors occurs for either zero or full-scale input since all capacitors are either fully discharged or fully charged, respectively.
For the same reason no offset error can arise from capacitor mismatch since the mismatch cannot be manifested unless a charge redistribution exists in the final configuration.
From
IEEE Journal of Solid-State Circuits, Vol. SC-10, NO. 6, December 1975. pp371~379
"All-MOS Charge Redistribution Analog-to-Digital Conversion Techniques-Part I"
By James L. McCreary & Paul R. Gray
Thanks you in advance. |
