查看: 6890|回复: 28
[Paper]1-V Power Supply CMOS Cascode Amplifier
发表于 2006-9-19 15:10:28 | 显示全部楼层 |阅读模式
Abstract—In this paper, we design a folded cascode operational transconductance amplifier in a standard CMOS process, which has a measured 69-dB dc gain, a 2-MHz bandwidth, and compatible input- and output voltage levels at a 1-V power supply. This is done by a novel current driven bulk (CDB) technique, which reduces the MOST threshold voltage by forcing a constant current though the transistor bulk terminal.We also look at limitations and improvements of this CDB technique.
Index Terms—1-V OTA, CMOS, current driven bulk, ultra-low voltage.
[ 本帖最后由 gmc832002 于 2006-9-19 15:32 编辑 ]
1-V power supply CMOS cascode amplifier.pdf
115.61 KB, 下载次数: 128 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-9-19 22:00:36 | 显示全部楼层
Thanks!!
 楼主| 发表于 2006-9-21 11:54:57 | 显示全部楼层
为什么IEEE上的paper没有人来下呢,很纳闷啊!
发表于 2006-9-26 00:54:54 | 显示全部楼层
I
I want
I want to
I want to download !
发表于 2006-12-24 16:52:50 | 显示全部楼层
发表于 2006-12-24 16:54:09 | 显示全部楼层
发表于 2006-12-24 17:06:51 | 显示全部楼层
全英文的?
发表于 2006-12-24 18:05:08 | 显示全部楼层
Thanks!!
发表于 2007-1-15 19:49:28 | 显示全部楼层
ke xi you le
发表于 2007-1-19 21:08:37 | 显示全部楼层
GMT+8, 2025-12-30 23:19 , Processed in 0.071830 second(s), 7 queries , Gzip On, Redis On.
