楼主: SamsungMonitor
Cadence Low Power Methodology Kit - LPKIT82
 楼主| 发表于 2010-7-15 22:57:12 | 显示全部楼层
Note:
For those who install LPKIT82 in RHEL5.X, you might face some problems to get the decrypted files.
Please issue out if somebody cannot get the files.
Thanks.
Solution for 0 bytes of DATA.tgzaa and LIBS.tgzaa:
1.) You might not able to get the 18 folders and 1 file inside /home/eda/lp_kit8.2/kits/LP_KIT_HOME directory.
2.) What you get might be as shown below.
    DESIGN_REUSE
    DOCUMENTATION
    FP_IO_RING
    LIBRARY_DEV
    LIBS
    LP_CLP_LEC
    LP_DFT
    FP_ECO_METHODOLOGY
    LP_SI_TIMING_CLOSURE
    LP_SYNTHESIS
    LP_VERIFICATION
    POWER_PLANNING
    POWER_SIGNOFF
    PVS
    RTL
    SETUP
    TOOLS
    Copyright
    DATA.tgzaa     0 bytes
    DATA.tgzab     100MB
    DATA.tgzac     100MB
    DATA.tgzad     100MB
    DATA.tgzae     100MB
    DATA.tgzaf     100MB
    LIBS.tgzaa     0 bytes
    LIBS.tgzab     100MB
    LIBS.tgzac     100MB
    LIBS.tgzad     100MB
    LIBS.tgzae     100MB
    LIBS.tgzaf     100MB
    LIBS.tgzag     100MB
3.) For those who get the 0 bytes of "DATA.tgzaa" and "LIBS.tgzaa", you need to do some tricks in order to decrypt those files.
4.) Delete all the files under /home/eda/lp_kit8.2/kits/LP_KIT_HOME directory and do the configuration again.
5.) Monitor the LP_KIT_HOME from time to time during the configuration and decryption.
6.) Copy out the "DATA.tgzaa" and "LIBS.tgzaa" once it appear, both size are 100MB.
7.) When the configuration finish, you will see the "DATA.tgzaa" and "LIBS.tgzaa" under LP_KIT_HOME folder become 0 bytes (maybe is Cadence internal errors).
8.) Now copy the 100MB of "DATA.tgzaa" and "LIBS.tgzaa" to LP_KIT_HOME folder, replace them.
9.) Now under /home/eda/lp_kit8.2/kits/LP_KIT_HOME directory, you should have
    DESIGN_REUSE
    DOCUMENTATION
    FP_IO_RING
    LIBRARY_DEV
    LIBS
    LP_CLP_LEC
    LP_DFT
    FP_ECO_METHODOLOGY
    LP_SYNTHESIS
    LP_VERIFICATION
    POWER_PLANNING
    POWER_SIGNOFF
    PVS
    RTL
    SETUP
    TOOLS
    Copyright
    DATA.tgzaa     100MB
    DATA.tgzab     100MB
    DATA.tgzac     100MB
    DATA.tgzad     100MB
    DATA.tgzae     100MB
    DATA.tgzaf     100MB
    LIBS.tgzaa     100MB
    LIBS.tgzab     100MB
    LIBS.tgzac     100MB
    LIBS.tgzad     100MB
    LIBS.tgzae     100MB
    LIBS.tgzaf     100MB
    LIBS.tgzag     100MB
10.) Now open a new terminal.
cd /home/eda/lp_kit8.2/kits/LP_KIT_HOME
cat DATA.tgza* > DATA.tgz
cat LIBS.tgza* > LIBS.tgz
rm DATA.tgza*
rm LIBS.tgza*
tar -xf DATA.tgz
tar -xf LIBS.tgz
Please patient during the each process.
发表于 2010-7-15 23:05:50 | 显示全部楼层
发表于 2010-7-16 00:15:26 | 显示全部楼层
down完了,谢谢了
发表于 2010-7-16 04:17:27 | 显示全部楼层
thxxxxxxxx
发表于 2010-7-16 15:39:04 | 显示全部楼层
我解開的DATA.tgzaa           0KB
           DATA.tgzab  102'400KB
            DATA.tgzac  102'400KB
            DATA.tgzad  102'400KB
            DATA.tgzae  102'400KB
            DATA.tgzaf  101'636KB
請問一下各位大大 這樣正常嗎?
发表于 2010-7-16 15:48:08 | 显示全部楼层
我解開的LIBS.tgzaa           0KB
           LIBS.tgzab  102'400KB
           LIBS.tgzac  102'400KB
           LIBS.tgzad  102'400KB
           LIBS.tgzae  102'400KB
           LIBS.tgzaf   102'400KB
           LIBS.tgzag      4'435KB
請問一下各位大大 這樣正常嗎?
 楼主| 发表于 2010-7-16 16:10:54 | 显示全部楼层
我解開的LIBS.tgzaa           0KB
           LIBS.tgzaf   102'40 ...
ccpi 发表于 2010-7-16 15:48
Are you using RHEL5.X ???
发表于 2010-7-16 22:29:24 | 显示全部楼层
我解開的LIBS.tgzaa           0KB
是的,是因為OS的關係嗎?
发表于 2010-7-16 22:35:42 | 显示全部楼层
Thanks
发表于 2010-7-18 02:43:02 | 显示全部楼层
GMT+8, 2025-12-29 05:54 , Processed in 0.021123 second(s), 3 queries , Gzip On, Redis On.
