楼主: hehejiuaixiao
[讨论] 高手进,芯片ESD电路问题!?
发表于 2010-7-14 15:37:32 | 显示全部楼层
Q:你说的是GGMOS或者GCMOS?
A: for IO, i do not recommend you to use gate coupled MOS as ESD protection.
Q: 你说的是GGMOS或者GCMOS?
A: if you want to reduce the parasitic capacitance, use pure diode.
Q: V1,V3不用,可以么?
A: yes, if you don't care about V1 and V3,  and the chip will function well even if  V1 and V3 are damaged by ESD stress.
 楼主| 发表于 2010-7-14 15:44:18 | 显示全部楼层
11# zhukh
PIN脚被ESD击穿的话,不影响你的芯片内部电路么?
你说的 栅极耦合MOS 结构是怎么样的?
我知道,GGMOS是G,S短接!
发表于 2010-7-14 16:06:13 | 显示全部楼层
11# zhukh
so, why dont you add ESD protection? Every pin need ESD protection!
GCNMOS: C between Drain and Gate, R between Gate and Source.
 楼主| 发表于 2010-7-14 16:13:07 | 显示全部楼层
13# zhukh
如果用两个二极管加一个电阻来做ESD保护的话,那这两个二极管要用多大的?我现在用的CMOS工艺里,有PDIO和NDIO两种,但是面积选择多大的为好,还有这与pin串联的电阻要多大为好!?谢谢
发表于 2010-7-14 17:35:53 | 显示全部楼层
也不一定要加电阻。什么工艺,我没用过工艺提供的PDIO和NDIO二极管。自己画的,1.5um*20um, 3 finger is enough for 0.18um CMOS process. if you want to add resisitor, 100~200ohm is usually used.
 楼主| 发表于 2010-7-14 20:21:46 | 显示全部楼层
15# zhukh
TSMC .35 工艺,PDIO是做在n井里面的,NDIO是做在衬底上的!?
发表于 2010-7-14 21:51:00 | 显示全部楼层
我想PDIO应该是P+/Nwell diode, NDIO是N+/Pwell diode
for IO to GND, use N+/Pwell diode
for IO to VDD, use P+/Nwell diode.
or you can use P+/Nwell diode for both.
 楼主| 发表于 2010-7-14 23:48:07 | 显示全部楼层
17# zhukh
用的是单井工艺,N井工艺!~ESD保护用两个二极管,一个连VDD,一个连GND,两个二极管之间是输出PIN???是这样连么? 但是这个时候,二极管的尺寸(宽,长选多少合适呢?)
发表于 2010-7-18 14:57:27 | 显示全部楼层
it‘s ok that Pin 2 Pin ESD is Pass
发表于 2010-7-18 18:22:53 | 显示全部楼层
学习了。。。
GMT+8, 2025-12-18 06:44 , Processed in 0.017578 second(s), 3 queries , Gzip On, Redis On.
