查看: 10755|回复: 20
HOWTO: setting EXT9.1.2
发表于 2010-7-4 20:43:56 | 显示全部楼层 |阅读模式
Hi Friends, many people have sent me PMs asking for help about how to make EXT9.1.2 work especially to fix the problem with  DCM_Core.
First of all, if you want to download EXT9.1.2 here the link (thanks to SamsungMonitor)
http://bbs.eetop.cn/thread-254191-1-1.html?tid=254191&extra=page%3D1&page=1
it's an update so you don't need a previous version to install it.
it is installed as any Cadence tool with InstallScape 3.71
after installing it you should crack it.
The crack was given by vanduongbk (thanks for that)
i upload it here
sfk.tar.gz (363.79 KB , 下载次数: 243 )
Extact it to where ever you want
before applying the patch uncomment all your EDA environment setting from your bashrc.
1/copy sfk ,patch to folder install ,as ..../EXT912
2/use root ,run ./patch...
if you copied sfk to your folder install, you will have one error when applying the patch (doesn't matter)
assuming that that EXT 9.1.2 is installed in /EDA/Cadence/EXT912 here what you should add to your bashrc:
## QRCX
export QRC_HOME=/EDA/Cadence/EXT912
export QRC_ENABLE_EXTRACTION="t"
export PATH=$QRC_HOME/binQRC_HOME/tools/binPATH
About the license:
thanks to SamsungMonitor, here the features to be added to your license file:
FEATURE DFM_Core_Technology cdslmd 1000.0000 permanent uncounted \
        CDE40DAC230CC9A37918 VENDOR_STRING=SamsungMonitor HOSTID=ANY \
        ck=54 SIGN2="0F29 8C1B 7C08 0433 4A5D B17A 02B6 8FE0 A5BD C7A1 \
        AB96 CBDA CDCC 5FF5 1083 1CB7 88C6 7327 A071 58D2 9982 4F96 \
        B3CF 09A7 8510 7E5E 52AB 6437 732E 138B"
FEATURE Encounter_QRC_Extraction_GXL cdslmd 1000.0000 permanent \
        uncounted 7DF42D3CEC15D3B61A32 VENDOR_STRING=SamsungMonitor \
        HOSTID=ANY ck=83 SIGN2="1C85 AFE9 BBF9 98BE 194E 7B4C 196F \
        015A 2D4B 52BA 9C30 21DB CA98 64C1 F667 0FAD 9742 EC02 1760 \
        53EA 3B28 02E8 B4BE 5576 F274 F6C2 5999 CF29 5B2A F06B"
FEATURE Encounter_QRC_Extraction_L cdslmd 1000.0000 permanent \
        uncounted CD441D7C68F46F2CE03A VENDOR_STRING=SamsungMonitor \
        HOSTID=ANY ck=61 SIGN2="1D20 8B19 AB3B 649D 6D91 E8B8 9A25 \
        01E9 846C 19F4 4E4A C3DA 1643 442E C2C8 04AC 0626 5CDF 6384 \
        CC3E 1FC3 B21F 8C62 12C5 7E50 FBED A8D7 0F4E 8611 C223"
FEATURE Encounter_QRC_Extraction_XL cdslmd 1000.0000 permanent \
        uncounted 7D145DDCCAB2A7955587 VENDOR_STRING=SamsungMonitor \
        HOSTID=ANY ck=81 SIGN2="069B 9B67 69CA 6B1F 7535 CDC3 900B \
        90D6 8C13 B9B1 F6AD 2EB0 DF3D A7D3 A081 08AC C6FC B81F EFE9 \
        984C 1CEB 32E2 109D EB54 2783 CC7D 471E 80F0 5E72 84CF"
FEATURE Virtuoso_QRC_Extraction_GXL cdslmd 1000.0000 permanent \
        uncounted 8D943D6C097B3C6769ED VENDOR_STRING=SamsungMonitor \
        HOSTID=ANY ck=111 SIGN2="0FF2 CB48 A659 9DA8 E671 A91D 89DB \
        5EC0 87E3 88BE D1E4 ED69 6F0A 08DB FA54 126E 19F0 97C6 97A8 \
        CAB3 62F9 4B06 86B3 EAF9 66B2 64A3 C7BC 4F8A 19C9 3BBF"
FEATURE Virtuoso_QRC_Extraction_L cdslmd 1000.0000 permanent \
        uncounted 2D043D5CD629A2260F5B VENDOR_STRING=SamsungMonitor \
        HOSTID=ANY ck=60 SIGN2="188D CC77 67B2 3C0D 004D 0DA3 E2FD \
        6773 FF50 FEBF 44EC 5962 7658 7244 B037 0F1B 7A0A 0418 F23C \
        D98B D9F8 A56D E097 8B19 E661 1489 ED54 56A9 EC4A 7C57"
FEATURE Virtuoso_QRC_Extraction_XL cdslmd 1000.0000 permanent \
        uncounted DD240DBC5E2EAEC7CB01 VENDOR_STRING=SamsungMonitor \
        HOSTID=ANY ck=120 SIGN2="1C2C 32DB 58C0 97D8 1C06 97C6 0724 \
        8B8B B45E 1DA8 1860 0E41 E16B A653 5EE4 0A1E 3189 CAEB 4FC9 \
        887E D06B E993 7CB8 028D 87CF 779E 20ED 05B5 478D 75E2"
FEATURE QRC_Advanced_Analysis cdslmd 1000.0000 permanent uncounted \
        AD247D6C0DFE1E288001 VENDOR_STRING=SamsungMonitor HOSTID=ANY \
        ck=47 SIGN2="0D20 A896 68B3 8BDF E8CC B106 27FF 0037 FF14 A5B7 \
        14E5 07F3 2118 7969 8ED4 137C EC5E 74D8 1D00 D6CD 02A2 1C6E \
        11D9 9AFD AF03 7B5B F416 CC8A 3337 A2D4"
FEATURE QRC_Advanced_Modeling cdslmd 1000.0000 permanent uncounted \
        1D64AD4CEDC8ADA70B8E VENDOR_STRING=SamsungMonitor HOSTID=ANY \
        ck=133 SIGN2="065A 416F E3F7 A3B4 CE06 3B50 D8CE BC91 1112 \
        FA18 0A95 F878 5964 71E5 3977 081A 8AF2 AC8E 3579 D645 60F3 \
        449D 6764 C1EB 9924 35F9 53A3 8FC7 6DBB 1DCD"
the features cover:
DFM_Core_technology
to make it work you should use an older version of lmgrd and cdslmd (i uploaded them)
or you can get them from IC610 (/EDA/Cadence/IC610/tools/bin/)
lm.tar.gz (571.09 KB , 下载次数: 204 )
just refer to them in the license file:
DAEMON cdslmd  /EDA/Cadence/IC610/tools/bin/cdslmd
and in your bashrc:
alias startca='x/EDA/Cadence/IC610/bin/lmgrd  -c /EDA/Cadence/licenses/license.dat  -l /tmp/cadence.log'
here some screenshot:
Hope it will will work for you
Best Ragards
TheShaDowX
 楼主| 发表于 2010-7-5 03:43:02 | 显示全部楼层
no thanks!!!!!???
头像被屏蔽
发表于 2010-7-5 09:54:53 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2010-7-6 02:15:58 | 显示全部楼层
发表于 2010-7-6 07:02:12 | 显示全部楼层
thank you
发表于 2010-11-15 13:59:43 | 显示全部楼层
回頭測試一下看看
发表于 2011-10-4 11:13:31 | 显示全部楼层
thanks
发表于 2012-2-19 13:18:49 | 显示全部楼层
学习了,谢谢!
发表于 2012-3-12 19:09:38 | 显示全部楼层
看不到答案……
发表于 2012-10-2 15:41:14 | 显示全部楼层
Thank you very much! Your post very usefull and helpfull !
GMT+8, 2025-12-11 20:29 , Processed in 0.062207 second(s), 8 queries , Gzip On, Redis On.
