查看: 2233|回复: 1
[招聘] 【招聘】LSI上海研发中心正在扩张,诸多职业发展机会等着您!
发表于 2010-7-2 11:15:50 | 显示全部楼层 |阅读模式
LSI 上海研发中心火热招聘中,诸多职业发展机会等着您!欢迎有志之士加入!如有任何疑问,请发送邮件至Tracey.zheng@lsi.com或拨打电话021-24191709。也可加我msn:zql975504@hotmail.com
有意者,请将简历发至:Tracey.zheng@lsi.com
1.
Verification Design Engineer (Junior to staff level)
Responsible for Design, Verification and customer support of protocol systems. Good knowledge of High Speed Interconnects, Storage and Networking Protocols, such as PCI Express, Ethernet, Fibre Channel, Serial RIO, Interlaken. Good communication skill is must. Experience with FPGA prototyping/validation a plus.
PREFERRED EXPERIENCE:
Design skills:
- Micro-architecture development & RTL Design
- Synthesis & Timing analysis
Verification skills:
- Verification, including development of methodologies, test plans, compliance test suite, test bench & test cases, using System Verilog, Vera and Specman.
- Development of Bus Functional models (BFMs), transactors, assertions, and manage coverage and regressions
Standards development:
- Work with standards bodies such as IEEE and PCI SIG to develop industry standard specification for next generation product
Must be conversant with the following:
- Verilog, System Verilog, C++, EDA CAD tools,
- Synthesis, Timing constraints and Logic Equivalence
2.
ASIC Customer DFT Engineer
The Customer DFT Design Engineer is a challenging and cutting-edge position working with LSI internal methodology and foundation IP development teams to support complex ASIC designs for either external tier one customers or internal ASSP programs.
The ideal candidate should be strong in all DFT (Design for Test) for all aspects. This would include scan/TDF, TestKompress, MEMBIST/BISR, JTAG, etc. Having strong STA skills is a plus for timing for all aspects of test. Responsible for support / debug of customer designs after delivery of prototypes
Strong communications skills are important to this position. This is a position for developing and honing verbal and written communication skills, and for interfacing to many different people and engineering teams within LSI. Position requires weekly interface with LSI customers.
A successful candidate will have strong debug skills, good scripting skills, and hands on experience with physical design and test tools. Previous experience in taping out an ASIC or ASSP is ideal for this position.
Requirements:
experience in ASIC design and implementation. The candidate should have knowledge and hands on use of test insertion, vector generation and verification, and is familiar with Mentor FastScan and TestKompress, LogicVision, and scripting. Familiarity with Verilog RTL coding, Verilog Simulators (NC or VCS) , Synopsys Design Compiler, Synopsys ICC Physical design tools, PrimeTime for Static Timing Analysis, Verplex (or Formality) is a plus. The ideal candidate should have completed at least one successful ASIC or ASSP tapeout. Experience in working with customers desired. Experience in working with and debugging prototypes considered a strong plus. Some experience with Signal integrity a bonus. Must possess excellent communication skills; be able to effectively communicate with other members of the design team, supporting organizations, and management.
Education: BS/MS Electrical, Computer Engineering or Equivalent
3
Preamp Analog/Mixed Signal Design Engineer
JOB DESCRIPTION:
- Design high speed analog and mixed-signal integrated circuits within custom chips for the
hard disk drive industry
- Work directly with customers to determine system requirements, write specifications and
guide customers in the use of pre-amplifier products
- Use high speed electronic characterization equipment to evaluate and debug the
functionality of the design once the part is fabricated in silicon
- Provide technical leadership through all phases of product development including test,
yield, characterization, reliability analysis, qualification and release to manufacturing
LSI's Storage Peripherals Group is looking for an experienced custom analog IC designer to
join the pre-amplifier design team. At LSI we are committed to innovation and industry
leadership. We develop advanced high-speed magneto electronic read/write IC architectures
as the basis for our products.
Design team members define, create and modify high-speed custom integrated circuits for
hard disk drive (HDD) products using leading edge CMOS and SiGe BiCMOS technologies.
Team members support the entire product life cycle beginning with design and moving through
test, qualification, release to production and ramp to volume.
- Degree in Electrical Engineering (or related field), MS required, Ph.D. preferred
- Minimum three to five years experience in discrete, transistor level analog circuit design
- Experience with analog and mixed signal IC product design, integration and verification is
required
- Strong physical layout knowledge and parasitic component understanding essential
- Process and device physics knowledge critical
- Proven skills using electronic measurement equipment in a lab environment
- Expertise in applied magnetism and recording a strong plus
4.
Preamp Analog/Mixed Signal Design Manager
JOB DESCRIPTIONSI is known
LSI is known worldwide as a storage market leader. Our silicon-to-systems solutions empower
disk drives with the intelligence, flexibility, speed and reliability needed for high-capacity
storage across every market segment, from portable consumer electronics devices to personal
computers to enterprise-class storage systems and networks.
LSI's Storage Peripherals Division is seeking an experience IC verification manager to join the
pre-amplifier team. Preamp team members define, create, modify and verify high-speed
custom integrated circuits for hard disk drive (HDD) and tape recording products using leading
edge CMOS and BiCMOS technologies.
Position Description
- Direct support and management of individual technical contributors, specifically analog
and mixed-signal design engineers. Responsibilities include hiring, performance
management and team development.
- Work with other functional managers and product managers to set and achieve aggressive
product development schedules critical to success.
- Define and implement analog and mixed-signal designs to achieve high quality products in
first-pass silicon.
- Must be comfortable working with internal and external customers and suppliers.
- Minimum three years experience managing circuit design teams
- Expertise with design and layout of custom analog and mixed-signal circuits in CMOS and
BiCMOS technologies
- Experience in IC product development from concept to successful production
- Strong communication skills (must be proficient in both spoken and written English)
- Able to travel internationally (to United States and throughout Asia)
- Understanding of silicon process technologies (CMOS and bipolar) and device physics
5.  Test Engineer
DESCRIPTION OF DUTIES IN ADDITION TO THOSE IN JOB DESCRIPTION:
- To support prototype and production releases of new products. Manage debug of test program, design and debug of test hardware, and meet product release schedule.
- Support test program development for implementing changes in new test methodologies for test coverage improvement.
- Pursue Design for Test initiatives to optimize testability and achieve test cost reduction via test time reduction and multiple site test solutions for production release.
- Support test chip test development and characterization of new IP used in LSI products.
- University graduate students with top scores in GPA
- Prior working experiences in the semiconductor industry field, specially in either IDM, Fabless, or Foundry environment
- ATE programming skills would be essential
- C++ and/or Perl programming skills
6.
ASIC Customer Design Engineer (Junior to Staff level)
JOB DESCRIPTION:
The Customer Design Engineer is a challenging and cutting-edge position working with LSI
As an integral member of the customer design engineering team, the ASIC Customer Engineer
has responsibility for a wide range of tasks, including chip floor planning, place and route,
timing analysis, signal integrity, test, and design verification.
Responsible for support and completion of designs from customer provided RTL or Gate level
netlist using the latest LSI technologies.
Design completion tasks include
- Presales Support (die size support, memory generation, address customer questions and
concerns.)
- RTL Analysis & Synthesis
- Physical Design Implementation (bonding, floor planning, power structure insertion, place
and route, timing closure) using Synopsys Astro or ICC tools
- Test insertion using Mentor, LogicVision, or Virage tools
- Formal Verification (Verplex or Formality)
- Static Timing Analysis (Primetime and Primetime SI)
- Cross talk analysis
- Power verification
- DRC & LVS
8.  Preamp Digital IC Design Engineer
JOB DESCRIPTION:
LSI Corporation is known worldwide as a storage market leader. The LSI pre-amplifier group
has experienced double-digit market share growth for the past three consecutive years. Our
silicon-to-systems solutions empower disk drives with the intelligence, flexibility, speed and
reliability needed for high-capacity storage across every market segment, from portable
consumer electronics devices to personal computers to enterprise-class storage systems and
networks.
LSI is actively seeking experienced engineering professionals to join the Storage Peripherals
Group. As our team drives toward the #1 market position, talented analog design engineers
are needed. Show us that you have what it takes to be #1. Join our team!
Position Description:
A preamp design engineer's duties include working within a highly motivated product
development team to create and modify the digital core of our mixed-signal product. You will
also support the cross functional team in taking products from the initial design phase through
to high volume production.
Job Responsibilities Include:
- Communicate effectively within a global business environment (must be proficient in both
spoken and written English).
- Work directly with our world wide customers to define system requirement, digital control
function and block partition of the next generation preamplifier product. Perform digital
logic design, verilog coding, logic synthesis, both RTL and gate level verification, formal
verification and static timing analysis as well as place and routing.
- Support the integration of digital core with other analog circuitry into a completed
integrated circuit. Work with analog designers to conduct AMS top level simulation to verify
the functionality of the whole chip.
- Perform some transistor level high speed digital integrated circuit design various cells and
blocks within custom chips for the hard disk drive industry. Examples of cells and blocks
include multiplexors, adders, multipliers, dividers, specific functional macro blocks,
- Conduct detailed design reviews of the digital core to internal and external customers.
- Use high-speed electronic characterization equipment to evaluate and debug the
functionality of the silicon.
- Provide technical support and guidance to a cross functional team of engineers through all
phases of product development which includes: test, yield, characterization, reliability
analysis, qualification, and release to manufacturing.
- Adhering to schedule, die size, and power commitments.
- Preferred degree in Electrical or Electronic Engineering.
Confidential
- BS required, MS or Ph.D. preferred
- Minimum of 3 years Digital IC design experience
- Minimum of 3 years product development experience
- Proven experimental skills using electronic measurement equipment in a lab environment.
- Expertise in applied magnetism and recording systems is a plus.
- Experience with ASIC EDA tools used in synthesis, simulation, static timing analysis,
formal verification, place and routing.
- Familiar with Verilog/VHDL
- Understanding of silicon process technologies (CMOS and Bipolar) and device physics
would be a plus.
- Experience in developing simulation and verification test benches
Proven analytical skills (application of math and physics to solve problems)
9. Digital IC Design Engineer
JOB DESCRIPTION:
- Working with an Architecture/Algorithm Development Team to finalize system architecture
for optimal implementation of digital signal processing algorithms, including architectural
definition and tradeoffs, die size estimation.
- Digital logic design, verilog coding, logic synthesis, both RTL and gate level verification,
formal verification and static timing analysis.
- Work very closely with physical design engineers from floorplan through final parasitic
extraction to ensure smallest area and highest performance possible.
- Experience in logic design, synthesis, static timing analysis, and verification
- Experience with ASIC EDA tools used in synthesis, simulation, static timing analysis, and
formal verification
- Knowledge of Verilog/VHDL design languages
- Excellent technical troubleshooting and demonstrated problem solving skills
- Must be willing to follow a structured design approach including design for reuse and
provide thorough design documentation
10. Verification Engineer
- Duties will include working with and leading a Verification Team to develop reusable block
and system level verification environment using high level verification language to support
ASIC development.
- Review RTL architectural and implementation specifications. Develop test plan, create
stimulus drivers, monitors, reference models, scoreboards, protocol checkers to verify
function and performance of advanced multiprotocol networking ASICs.
- Define and develop application tests required to verify ASICs meet functional and
performance goals.
- Define and implement functional coverage plans.
- Define and implement code coverage plans. Develop testing and regression
methodologies for new verification flow.
- Coordinate test plan implementation and regressions with remote team.
- Incorporate reusability into all aspects of the verification environment.
- Develop/maintain/enhance environment tools/scripts/makefiles.
- Proven ASIC Design Verification skills
- Proficient with high level verification languages such as System Verilog and Specman e.
- Knowledge of data and telecommunication networking
- Proficient with one or more scripting languages, such as Shell, Perl and TCL.
- Superior debugging skills for large ASIC designs
- Strong written and verbal communication skills
- Adaptable to evolving customer requirements
- Experience in a lead position giving guidance to other engineers, tracking and overseeing
development progress.
Education/Certifications:
Required Degree: BS
Preferred Degree: MS
Preferred Major: Electrical Engineering or related discipline
11. DSP Sys Application Manager
JOB DESCRIPTION:
This position is part of a growing team supporting our latest generation of DSP solutions for
media gateway, cellular baseband, and video applications. This manager will support a team of
system applications engineers working directly with major customers to assist with porting,
integration and debugging of various software modules. Customer interaction includes both presales
activities and issue management during development phases. Ability to work well with a
variety of people and disciplines is required. Occassional travel to customer sites is expected.
Excellent communications skills in both Chinese and English are required.
Requirements
- 4 years experience as applications engineer or in product development
- Additional 2 years experience managing an engineering team
- Excellent written and verbal communications in both Chinese and English
- Embedded software development/debug experience
- General knowledge of communication technologies and protocols
Desired:
- Experience with media gateways, cellular baseband or video transcoding
- Specific experience with ARM processors and/or StarCore DSPs
- Previous interaction with major telecom vendors in China
Education
Required Degree: BS
Preferred Major: Electrical Engineering, Computer Science, or related disciplines
发表于 2010-7-4 08:50:47 | 显示全部楼层
还在招啊
GMT+8, 2025-12-23 02:57 , Processed in 0.013850 second(s), 4 queries , Gzip On, Redis On.
