查看: 23200|回复: 32
[求助] pitch与grid有什么区别
发表于 2010-6-29 21:45:04 | 显示全部楼层 |阅读模式
工艺中,除了top metal (m6),其他的金属层,两者都相同,请问这两个有什么区别,不都是走线间隔??
发表于 2010-7-29 11:22:41 | 显示全部楼层
pitch 是金属线中心点与金属线中心点的距离。
grid 是走线每画一条线的最小线宽。
发表于 2010-10-8 14:59:22 | 显示全部楼层
回复 2# haydnzhang
    也就是说pitch为金属线间的最小间距,而grid为金属布线的最小宽度??可以这样理解吗??
发表于 2010-10-8 22:59:11 | 显示全部楼层
好像pitch的说法有点问题,最小线间距是spacing, pitch=spacing + 最小线宽
发表于 2010-10-13 20:22:08 | 显示全部楼层
学习了
发表于 2010-10-16 17:35:02 | 显示全部楼层
To complete the expllanation:
Grid has two meanings:
-custom layout grid: Grid is tool setting. But technology has some requirement on minimum grid resolution.
- Router grid: Grid here is hypothesis grids that the routing will be over them (As much as possible).
Pitch is related to DRC.
pitch=spacing+width.
Place and route tools may suppose a little larger value for the pitch to have better routing.
So the spacing of routing grids are the value of pitch.
发表于 2010-10-18 22:24:58 | 显示全部楼层
学习了。
发表于 2010-10-18 23:39:08 | 显示全部楼层
之前对这些概念比较模糊,学习了~
发表于 2010-11-14 21:59:59 | 显示全部楼层
受教了!
发表于 2010-11-15 11:44:54 | 显示全部楼层
route的时候,其实质就是将std cell的pin根据netlist的关系连接起来,布线工具要求pin的位置必须要放在grid上面。
GMT+8, 2025-9-17 07:02 , Processed in 0.019773 second(s), 6 queries , Gzip On, Redis On.
