查看: 2767|回复: 4
《精通verilogHDL语言编程》中一个例子的讨论
发表于 2010-6-29 14:22:34 | 显示全部楼层 |阅读模式
《精通verilogHDL语言编程》P472页一个三级CIC抽取滤波器的例子。。。
首先,我觉得这个例子有些不妥,我改正如下,然后可以综合。。。
其次,我不明白,P474页对VerilogHDL代码的验证,课本说,在MATLAB中输入一下程序,M=2;
        N=3;
        R=32;
        x=100.ones(1,300);
        q=quantizer([8:0],'fixed');
       y=cicdecimate(M,N,R,x,q);
表示该程序输入一个幅值为100的阶跃信号,经过CIC抽取器后,输出波形y(m)(图没有列出,课本上有)。
    请问它是怎么把Matlab和Modelsim进行联合仿真的啊?请明白人过来指点迷津。。。谢谢
这是本人修改后的CIC程序,可以综合,因为想在仿真时看到寄存器的值,把存储器改成了寄存器。。。
module cic3_decimator(reset,clk, x_in, y_out);
parameter STATE_HOLD = 1'b0, STATE_SAMPLE = 1'b1;
input reset;
input clk;
input  [7:0]   x_in;   //the input bit 8
output [25:0] y_out;   //the output bit 26
reg state;        // state register
reg derived_clk;  //get a clock
reg [4:0] counter;
reg [25:0] ComReg00,ComReg01,ComReg02,ComReg10,ComReg11,ComReg12,ComReg20,ComReg21,ComReg22,ComReg3;
reg [25:0] IntReg0,IntReg1,IntReg2;
reg [7:0] x;
wire [25:0] sxtx;    //sign extended input
assign y_out = ComReg3;
assign sxtx = {{18{x_in[7]}},x_in};
[email=always@(negedge]always@(negedge[/email] clk or negedge reset)
begin
    if(!reset)
    counter<=5'b0000_0;
    else
     counter <= counter + 1;
end
always @(negedge clk or negedge reset)
begin
   if(!reset)
    state<=STATE_HOLD;
else
case(state)
STATE_HOLD: if(counter == 31)
     state <= STATE_SAMPLE;
STATE_SAMPLE:
       begin
    ComReg00 <= IntReg2;
    state <= STATE_HOLD;
   end
default:
endcase
end
begin
    if(!reset)
    derived_clk<=0;
    else
    begin
  if((counter>8)&&(counter<16))
   derived_clk <= 1;
  else
   derived_clk <= 0;
  end
end
always @(posedge clk or negedge reset)
begin
    if(!reset)
    begin
    IntReg0<=0;
    IntReg1<=0;
    IntReg2<=0;
    end
    else
    begin
  //x  <= sxtx;
  IntReg0 <= IntReg0 +sxtx;
  IntReg1<= IntReg1 + IntReg0;
  IntReg2<= IntReg2 + IntReg1;
end
end
always @(posedge derived_clk or negedge reset)
begin
    if(!reset)
    begin
        ComReg00<=0;
        ComReg01<=0;
        ComReg02<=0;
        ComReg10<=0;
        ComReg11<=0;
        ComReg12<=0;
        ComReg20<=0;
        ComReg21<=0;
        ComReg22<=0;
        ComReg3<=0;
    end
    else
       begin
  ComReg01<= ComReg00;
  ComReg02<= ComReg01;
  ComReg10<= ComReg00 - ComReg02;
  ComReg11<= ComReg10;
  ComReg12<= ComReg11;
  ComReg20<= ComReg10 - ComReg12;
  ComReg21<= ComReg20;
  ComReg22<= ComReg21;
  ComReg3    <= ComReg20 - ComReg22;
    end
end
endmodule
这个程序是能够综合。。。
 楼主| 发表于 2010-6-29 15:08:30 | 显示全部楼层
大家关注下。。。。。。
 楼主| 发表于 2010-6-30 10:09:15 | 显示全部楼层
自己顶一下,希望引起注意
 楼主| 发表于 2010-6-30 22:01:37 | 显示全部楼层
再次顶一下,希望高手帮忙指导下
发表于 2010-10-22 17:29:58 | 显示全部楼层
顶顶顶顶顶顶顶顶顶顶顶顶顶
GMT+8, 2025-9-22 03:01 , Processed in 0.024339 second(s), 5 queries , Gzip On, Redis On.
