楼主: yongbyb2004
求助synopsys installer 安装问题
发表于 2011-11-8 00:39:23 | 显示全部楼层
Site ID 应该如何设置??
发表于 2011-12-6 18:39:12 | 显示全部楼层
The license file of synopsys SCL 11.x or later needs site ID for encoding and license verification, so it will not work using old EFA gen.
发表于 2011-12-7 00:19:14 | 显示全部楼层
You can just use site ID 000 (the default). The error you get is not /caused/ by the site ID. The error you get just says your license is invalid, which means using a different crack.
发表于 2011-12-12 09:11:32 | 显示全部楼层
楼上的,“which means using a different crack”这是啥意思?
发表于 2011-12-12 09:38:45 | 显示全部楼层
which means using a different crack是什么意思?
发表于 2012-3-25 22:51:12 | 显示全部楼层
跪求x86_64的synopsys insstaller,哪位大侠有发一下呗,
感激不尽,感激不尽~~~
发表于 2012-3-28 16:59:39 | 显示全部楼层
回复 10# heritor
    请问下你这个问题解决了没?小小弟今天安装也遇到这个问题了,囧囧
发表于 2012-5-3 23:42:01 | 显示全部楼层
遇到同样问题!!!
发表于 2012-11-2 17:54:34 | 显示全部楼层
楼主最后解决了吗???一样的问题啊???苦于头绪~~~
发表于 2013-4-19 20:55:22 | 显示全部楼层
Your site ID number is in the upper-right corner of your Synopsys license
key certificate. If you have trouble locating it, contact your Synopsys
representative.
GMT+8, 2025-9-18 04:25 , Processed in 0.016578 second(s), 4 queries , Gzip On, Redis On.
