查看: 17584|回复: 2
simulink仿真观察频谱,接上spectrum scope后出现如下错误,请教高手该如何修改?
发表于 2010-6-10 15:52:29 | 显示全部楼层 |阅读模式
Error evaluating registered method 'PostPropagationSetup' of M-S-Function 'sdspfscope2' in 'cdma_ddc/Spectrum Scope/Frame Scope'. Error using ==> sdspfscope2>errorIfSampleBasedAndNotBuffered at 270
When the input to the Spectrum Scope block is sample based, you must select the "Buffer input" check box.
发表于 2010-11-12 09:19:33 | 显示全部楼层
双击spectrum scope 将buffer input 和specify FFT length选择试试!
发表于 2011-4-23 16:54:17 | 显示全部楼层
回复 2# 袁园
   你好,你能解释下这个buffer input 和specify FFT length的意义吗?如果你有这方面的资料能给传下吗? 谢谢>  baijidetian@126.com
GMT+8, 2025-10-21 09:33 , Processed in 0.017250 second(s), 5 queries , Gzip On, Redis On.
