查看: 3309|回复: 9
[资料] A low-jitter RF PLL frequency synthesizer
发表于 2010-5-19 13:58:47 | 显示全部楼层 |阅读模式
王志功2010年5月新论文
A low-jitter RF PLL frequency synthesizer with high-speed mixed-signaldown-scaling circuits
09061901[1].pdf
4.79 MB, 下载次数: 88 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2010-5-19 16:02:00 | 显示全部楼层
ganxie
发表于 2010-5-19 16:47:03 | 显示全部楼层
Thanks!!!!
发表于 2010-5-20 08:01:13 | 显示全部楼层
下来看看,谢谢。
发表于 2010-5-20 11:43:01 | 显示全部楼层
8888888
 楼主| 发表于 2010-5-20 14:06:30 | 显示全部楼层
怎么没有人下载呢?下后请留言啊!
 楼主| 发表于 2010-5-20 14:22:27 | 显示全部楼层
在此为大家详细介绍一下摘要
[b]abstract:
      A low-jitter RF phase locked loop (PLL) frequency synthesizer with high-speed mixed-signal down-scaling circuits is proposed. Several techniques are proposed to reduce the design complexity and improve the performance of the mixed-signal down-scaling circuit in the PLL. An improved D-latch is proposed to increase the speed and the driving capability of the DMP in the down-scaling circuit. Through integrating the D-latch with ‘OR’ logic for dual-modulus operation, the delays associated with both the ‘OR’ and D-flip-flop (DFF) operations are reduced, and the complexity of the circuit is also decreased. The programmable frequency divider of the down-scaling circuit is realized in a new method based on deep submicron CMOS technology standard cells and a more accurate wire-load model. The charge pump in the PLL is also realized with a novel architecture to improve the current matching characteristic so as to reduce the jitter of the system. The proposed RF PLL frequency synthesizer is realized with a TSMC 0.18-μm CMOS process. The measured phase noise of the PLL frequency synthesizer output at 100 kHz offset from the center frequency is only –101.52 dBc/Hz. The circuit exhibits a low RMS jitter of 3.3 ps. The power consumption of the PLL frequency synthesizer is also as low as 36 mW at a 1.8 V power supply.
为方便大家,适合的可选取下载,不适合自己的看看即可,省点你们的信元!
发表于 2016-5-18 19:05:35 | 显示全部楼层
THANK YOU
发表于 2017-10-3 21:18:01 | 显示全部楼层
thnx!
发表于 2022-7-3 10:48:25 | 显示全部楼层
学习
GMT+8, 2025-12-22 08:48 , Processed in 0.029613 second(s), 5 queries , Gzip On, Redis On.
